I want to run 12's w/o touching the engine
Old May 11, 2003 | 07:45 AM
xkhalil333x's Avatar
Default I want to run 12's w/o touching the engine
I want to run 12's w/o touching the engine. 1995 gsr with i/h/e fuel pump/regulator jackson racing 6lb pulley with crv crank with slicks? If not what shall i do to run that w/o spending more than 2500 for used parts
Regards
Old May 11, 2003 | 07:51 AM
Rory Breaker's Avatar
Default Re: I want to run 12's w/o touching the engine (xkhalil333x)
Running 10PSI? Hondata it, strip it and welcome to the 12's.
I would imagine you could use some injectors to utilize that setup even without Hondata, as well as an LSD. If youre tuned right, you shouldnt have any problems.
Old May 11, 2003 | 07:59 AM
thanks
Old May 11, 2003 | 08:25 AM
obd2gsr's Avatar
remove everything in the interior you don't need, all your accesories (Power steering, AC if you live in a place where you don't need it), add a flywheel/clutch combo, remove everything in the trunk, practice at the track, VOILA, 12.xx....
and good luck! let us know what happens. and if you don't make 12's, what time you do get.
Honda007
Mar 6, 2006 07:14 PM
99b18
Mar 18, 2004 05:21 PM
92lSilude
Oct 15, 2003 02:12 PM
bumpin_bass
Aug 26, 2003 10:32 AM
AllMotorITR
Aug 14, 2002 09:48 AM
