who had prodrive oil gear?? im thinking about getting one
Old May 11, 2003 | 07:13 AM
ludesleep's Avatar
Default who had prodrive oil gear?? im thinking about getting one
anyone have one of these? are they worth buying for my build up cause im gonna be boosting alot 22-25psi
Old May 11, 2003 | 10:13 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: who had prodrive oil gear?? im thinking about getting one (ludesleep)
i got one just to be safe
Old May 11, 2003 | 01:43 PM
BoostedH23a1's Avatar
Default Re: who had prodrive oil gear?? im thinking about getting one (Boosted97Lude)
sam.. u get your running yet... everytime i see it the motors not in it...
Old May 11, 2003 | 04:12 PM
ludesleep's Avatar
Default Re: who had prodrive oil gear?? im thinking about getting one (BoostedH23a1)
since this oil gear is steel does that mean your oil temp is gonna go up? Steel gets alot hotter doesnt it?
Old May 11, 2003 | 04:18 PM
JG Luder's Avatar
get the prodrive and never look back.
if there were problems with heating, or failure, or whatever... there wouldn't be this many top racers using them.
The final answer for the day IS:
BUY ONE
Old May 11, 2003 | 04:42 PM
satan_srv's Avatar
Default Re: who had prodrive oil gear?? im thinking about getting one (Lone Luder)
I have one, always good to have, cause if you ever shatter your oil pump you won't know until your engine is toast.
Old May 11, 2003 | 06:30 PM
Ima2nr's Avatar
Default Re: who had prodrive oil gear?? im thinking about getting one (satan_srv)
I bought it, just in case... this months issue of HCI has about a 15 page story on the Mopar powered drag Neon. if you read the article, they talk about the old oil pump they used to use, and if the engine had a hick-up or misfire it would sometimes shatter the gear... that makes me more confident that my money was well spent.
Old May 11, 2003 | 07:19 PM
HotWheelz's Avatar
Default Re: who had prodrive oil gear?? im thinking about getting one (Ima2nr)
I have a prodrive also.
Old May 11, 2003 | 07:21 PM
ludesleep's Avatar
Default Re: who had prodrive oil gear?? im thinking about getting one (HotWheelz)
are you guys buying new oil pumps and throwing these in or just using your old pumps?
Old May 11, 2003 | 07:24 PM
Boostless97Lude
Guest
Posts: n/a
old pump with the new gear
Old May 11, 2003 | 09:58 PM
fastludeh22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted97Lude &raquo;</TD></TR><TR><TD CLASS="quote">i got one just to be safe</TD></TR></TABLE>
new pump, why the hell would you not buy a new one for ~$50.
Old May 11, 2003 | 10:11 PM
ludesleep's Avatar
Default Re: who had prodrive oil gear?? im thinking about getting one (fastludeh22)
$50! please tell me were you seen this price cause i can only find them for 150.
Old May 12, 2003 | 07:48 AM
yea they are around 150
Old May 12, 2003 | 07:55 AM
2point6's Avatar
I run one as well.
Old May 12, 2003 | 07:56 AM
Boostless97Lude
Guest
Posts: n/a
why the hell would you buy a whole new pump and THEN on top of everything buy a ProDrive gear, the most important part of the pump is the gear, so with a ProDrive gear, it is POINTLESS to buy a whole new pump for the housing alone, just buy new gaskets for it, spend 5 bux
Old May 12, 2003 | 09:33 AM
kwik93si's Avatar
hey ludesleep, how much are you asking for the sleeved h23 and who did it for you?
Old May 12, 2003 | 03:07 PM
ludesleep's Avatar
Default Re: who had prodrive oil gear?? im thinking about getting one (kwik93si)
Vilas motors (local shop) i was asking 400 for it but i found out it need agline bored so im asking 300+shipping now
Old May 12, 2003 | 04:47 PM
98lude's Avatar
I recalled that this topic has been discussed before in the forced induction forum, and tony1 ( from jotech I think) and some others were all against it. They were saying that prodrive one is more prone to failure than OEM. I also remember that he mentioned that quite a lot of pro racers are using the stock one instead.
Old May 12, 2003 | 04:52 PM
ludesleep's Avatar
Default Re: who had prodrive oil gear?? im thinking about getting one (98lude)
really? see i would think steel would heat up alot more causing things to get alot hotter. I dont know for 300 bucks there should be no cons to this.
Old May 12, 2003 | 05:26 PM
ApexiAccord's Avatar
agreed with 98 lude they all switched back to stock saying that PRODRIVE itself couldnt handle up. so they all switch back to stock . try asking in the drag racing forum and FOrced induction. see what they have to say all bout it
Old May 13, 2003 | 03:38 PM
Mikeyslude's Avatar
These are billet steel.
Modified by Mikeyslude at 9:59 PM 6/25/2003
Old May 13, 2003 | 05:13 PM
Default Re: (Mikeyslude)
yea i heard that too
Old May 14, 2003 | 07:43 AM
kwik93si's Avatar
yea my mechanic had to switch over to the pro drive one because at every event he'd break a brand new oem oil pump. his car is a '93 hb that ran 9.40 @ 158mph
http://www.splitfireperformance.com
Old May 14, 2003 | 08:00 AM
DLB1994's Avatar
Default Re: (kwik93si)
am running stock oil gear in my turbo h23
i didnt get one because a few people i know could not get the provide gear to fit on the h23 oil pump
Old May 14, 2003 | 08:49 AM
Greyout's Avatar
Default Re: (DLB1994)
The oil pump should be the same. If not, couldn't you just use a H22 oil pump?
black93octane
Transmission & Drivetrain
Oct 9, 2012 08:31 AM
AMS MIKE
Aug 15, 2010 11:54 PM
88CRXHybrid
Mar 8, 2002 02:08 PM
