integra zc vs. civic zc?
are u talking about the usdm integra zc vs the jdm civic zc ? if u are the integra only has 118 hp and cant be used as a bolt on in the 4th gne civic, jdm civic zc 130hp and can be used in 4th gen civics
the brown cover can fit inside of a 4th gen but you have to make a custom driver side mount. but it's not worth it just go with the black (JDM) cover and you will love it :
Modified by MONSTERZC at 8:24 PM 5/11/2003
Modified by MONSTERZC at 8:25 PM 5/11/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MONSTERZC »</TD></TR><TR><TD CLASS="quote">the brown cover can fit inside of a 4th gen but you have to make a custom driver side mount. but it's not worth it just go with the black cover and you will love it
Unless you happen to get a black-top Integra ZC, in which case you will be very disappointed. Which I believe is the point of the question. The difference that I am aware of is the drivers side mount. It is on the front of the block, like the brown-top, and it allows you to bolt into a 3G Civic/1G CRX. The wiring for that swap is a little more difficult than a brown-top though.
</TD></TR></TABLE>Unless you happen to get a black-top Integra ZC, in which case you will be very disappointed. Which I believe is the point of the question. The difference that I am aware of is the drivers side mount. It is on the front of the block, like the brown-top, and it allows you to bolt into a 3G Civic/1G CRX. The wiring for that swap is a little more difficult than a brown-top though.
oo, i got confused from reading the info on hjasport.com. I just didnt want the brown valve cover that only goes into the 3g civic and 1g integra. Now I gotten it straigt that the black fit and the brown doesnt fit in the 4g civics. Is that correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91_hatch_si »</TD></TR><TR><TD CLASS="quote">oo, i got confused from reading the info on hjasport.com. I just didnt want the brown valve cover that only goes into the 3g civic and 1g integra. Now I gotten it straigt that the black fit and the brown doesnt fit in the 4g civics. Is that correct?</TD></TR></TABLE>
To keep the answer simple. YES
Ahknodd
May 1, 2003 07:47 AM
