AC Convert to r134?
Hi y'all,
I'm doing some work on my non-functional A/C system tomorrow on the Civic, and I'm considering converting it to R134. Any thoughts or suggestions? Is it compatible?
Thanks!
Thanks!
make sure you dont do it the cheap way: get the BRASS fittings(they dont leak) new o-rings and fill it up to 80% of what it was on r12 with ester oil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeper4dr »</TD></TR><TR><TD CLASS="quote">i just recently re-installed my A/C in my civic and converted to R134 in the process.
but what are you asking?</TD></TR></TABLE>
Thanks for the input. I am mostly concerned about the compatibility of the existing oil and seals with R134. I have never performed a retrofit (but I have done work on R12 and R134 systems), but I have heard antecdotal evidence about seals and/or oil in old systems being incompatible for retrofits in other cars.
Just wondering if a proper 134 retrofit in an existing EF Civic system poses any compatibility problems. Here is what I have planned: install new dryer, install a used OE compressor (original is source of leak), evacuate system w/ vacuum pump, add R134 to recommended pressure.
Will it be reliable?
Thanks - Mike
Thanks - Mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsellxoutx »</TD></TR><TR><TD CLASS="quote">make sure you dont do it the cheap way: get the BRASS fittings(they dont leak) new o-rings and fill it up to 80% of what it was on r12 with ester oil
Are you recommending I replace ALL of the o-rings? That's a lot of work! There must be at least 10 of them in various obscure places of the car (2 each at the compressor, evaporator, condenser, exp. valve, dryer)! PITA!
I have R12 I can use, but I'd rather not. But if O-ring replacement is necessary, I think I'll avoid the retrofit. But is it necessary?
</TD></TR></TABLE>Are you recommending I replace ALL of the o-rings? That's a lot of work! There must be at least 10 of them in various obscure places of the car (2 each at the compressor, evaporator, condenser, exp. valve, dryer)! PITA!
you have to but i'd recommend it i have 134a in my 88hatch and it blows cold as fawk and it has been for the past year.the only thing that sucks is the fact that i had to sacrifice my far left vent for the hydro tranny conversion.
fact of the matter I LIVE IN TEXAS and dont sweat in my car
c1civic
14
May 15, 2005 02:55 PM
crazy eyez killa
Nov 30, 2004 09:24 AM
