people read this...I NEED HELP
Old May 10, 2003 | 09:06 PM
GDM Z28's Avatar
Default people read this...I NEED HELP
ok this just started happening tonight.....i have a eg hatch with a b18b swap. when i put the car in first gear and take off slow (off the line) it feels fine (normal). but if i take off fast it feels like my front right tire is rubbing (only for 2 seconds). it only does this in first gear and only if i go fast from a stop. what do you guys think it could be? please help me out here
car and motor are both 95', and the tranny was replaced 3 weeks before i bought the swap so i dont think thats the problem.
Old May 10, 2003 | 09:25 PM
euclid's Avatar
Default Re: people read this...I NEED HELP (civicflnum1)
i'd say its your wheel bearing in your hub, it may be broken and is making that noise due to the inital friction from a standing start.
the problem with that is i'm not sure you can diagnose it unless you press the hub out, which usually seperates the bearing anyway. you should jack your car up and make sure the axle boots are still secured, and maybe have someone stand outside the car when it happens so you can try to locate the source of the sound.
if you cant find it yourself take it to a shop, if it does turn out to be a bad bearing it is 60$ from honda and it has to be pressed in,
Old May 10, 2003 | 09:26 PM
civicHBphtride's Avatar
yo im from west palm beach!
and to help i dont know what it is could be a motor mount.
Old May 10, 2003 | 09:43 PM
allmtr's Avatar
Default Re: people read this...I NEED HELP (civicHBphtride)
do you have stock mounts??? maybe your belt is rubbing on something when it torques back so much.
Old May 10, 2003 | 10:30 PM
GDM Z28's Avatar
Default Re: people read this...I NEED HELP (allmtr)
it only started doing this tonight though me and my gf drove it all day then parked it at her house n took her car to a concert (i dont have a/c n florida is freaking hot!) then we came home n took my car out for a drive and when i started it up at her house n started to go it felt liek my tire hit my fender but it only does it from start in first gear! what kinda shop should check my hub n stuff?
Old May 11, 2003 | 04:30 AM
GDM Z28's Avatar
bump
Old May 11, 2003 | 11:36 AM
GDM Z28's Avatar
bump bump
Old May 11, 2003 | 11:47 AM
kKdARIAN's Avatar
Vice President/CEO
are you showing any signs of tire rub in the wheel well? if not then thats a quick way to rule the tire rubbin out' .. im thinkin motor mounts' my .02 worth
Old May 11, 2003 | 11:56 AM
ERA's Avatar
ERA
Yeah, kinda sounds like a motor mount here too. Then again, it could be a small animal caught up in there
Old May 11, 2003 | 03:56 PM
GDM Z28's Avatar
Default Re: people read this...I NEED HELP (kKdARIAN)
yup it was my rear mount, i went after work to my friends house n he found the problem! I wish uc ould of told me that last night it would of calmed me down ty for ur help guys!
94CivicSi
Transmission & Drivetrain
Mar 6, 2014 07:47 PM
01 itr dc2
Jul 14, 2006 01:48 AM
Mattyg2
Jun 12, 2005 06:23 PM
hondaracing1
Apr 23, 2004 05:09 PM
daddymaxx
Jan 25, 2004 06:12 AM
