Need help puttin my head on my Si motor
Old May 10, 2003 | 07:29 PM
DumpedSi's Avatar
Default Need help puttin my head on my Si motor
Well Ijust bought a 2000 si from auction that was theft recovery, pretty much the only thing that was wrong with is they took the head and tranny. I have every part needed to put this motor back together but I have never done it so Im curious if any of you would recommend I pay someone else to do it or if you think I should do it myself? Also is there any websites that have kinda of a step by step guide on how to do this.. thanks in advance!
Old May 10, 2003 | 07:33 PM
.RJ's Avatar
.RJ
Default Re: Need help puttin my head on my Si motor (MaKesDaGuRLsWeTT)
http://www.helminc.com
Old May 10, 2003 | 09:49 PM
Shaun's Avatar
Default Re: Need help puttin my head on my Si motor (.RJ)
try this write up http://hybrid2.honda-perf.org/tech/headswap/
Old May 11, 2003 | 04:26 AM
7PSI CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaKesDaGuRLsWeTT &raquo;</TD></TR><TR><TD CLASS="quote">the only thing that was wrong with is they took the head and tranny</TD></TR></TABLE>
They left the engine block and took just the head and tranny?
Strange...
I'd recommend you pull the rest of the motor out of the car, get it all bolted up together, and then reinstall the whole thing at once.
It's pretty much straight foward stuff.
Like they said above, get the repair manual, and take it from there.
Old May 11, 2003 | 04:29 AM
7PSI CRX's Avatar
Default Re: Need help puttin my head on my Si motor (7PSI CRX)
Now that I think about it, about the only reason I see someone taking just the head and tranny is because they knew the block was shot.
Stolen recovery, or Insurance Job?
I'd check out that block carefully.
Old May 11, 2003 | 06:10 AM
DumpedSi's Avatar
I think they left the block because it pretty much useless since it has vins on it and this way the car came back with a legit block
Old May 11, 2003 | 09:03 AM
Shaun's Avatar
true or they could have just wanted to finish there ls vtec swap with a b16 head and b16 Si tranny
chap
Feb 24, 2007 02:26 AM
1sikhatch
Mar 17, 2005 03:38 PM
safraz
Oct 4, 2004 06:13 AM
R6E6I6D
Jun 20, 2004 09:32 AM
mraudio13
Nov 22, 2002 07:02 AM
