A/F Gauge question
Old May 10, 2003 | 07:12 PM
CWBETB's Avatar
Default A/F Gauge question
Could anyone tell me when you should be concerned about running to lean by looking at a A/F Gauge? An example at full throttle at high RPM mine is showing 1st green "Rich" then goes to the last Stouch "yellow" before the rich. Is there a rule of thumb like mid range stouch is a problem etc?
Old May 11, 2003 | 04:25 AM
TwistedHatch's Avatar
Default Re: A/F Gauge question (CWBETB)
ya i'm wondering that too, i know my motor is running lean, the plugs are pretty white.......but i got a fpr now and i've gotten it richer up in the bottom of the stoich, and it pulls alot harder but it seems that it's still a little lean, is this guage pretty acurate, and where do you guys run them??
Old May 11, 2003 | 05:34 AM
spark's Avatar
Default Re: A/F Gauge question (TwistedHatch)
I think you should go wideband before break anything guys
Old May 11, 2003 | 07:24 AM
CWBETB's Avatar
I originally tuned mine with a wideband on the street. On the wideband we set my Zdyne to a safe tune. It just kinda throws me off that sometimes it will go to stouch a bit, other times its on 1st Green rich.
Old May 11, 2003 | 07:31 AM
CWBETB's Avatar
With the wideband we got 13.5-12.8 under full boost. (it would start out in the high 13 range and as the boost and RPM's increased the A/F got down into the high 12's.
This is running 8 pounds on a ZC
Old May 12, 2003 | 04:30 AM
CWBETB's Avatar
Ttt
prelude_problems
May 30, 2009 06:21 PM
nonvteclude
Feb 10, 2007 08:47 AM
LoseRPunKx182
Sep 26, 2005 09:06 AM
goofball123321
Oct 15, 2003 01:08 AM
lsteggy
Sep 23, 2002 08:47 PM
