70-80mph steering wheel shakes????help
Old May 10, 2003 | 07:11 PM
xhatchracerx's Avatar
Default 70-80mph steering wheel shakes????help
while i recently ran over a big piece of hard something on the road and it cracked my front fight rim, but to cut the story short i replaced all the rims and balanced them and remounted them, so my question is my steering wheel begins to shake at around 70-80 mph and its not a violent shake but its there and its considerably noticeable. i think it might be the outer tie rod, but i am not completely sure, is there anythign else that could cause steering wheel vibration?
Old May 10, 2003 | 07:19 PM
superrally's Avatar
Default Re: 70-80mph steering wheel shakes????help (xhatchracerx)
could be front rotors are warped... what type of "weight" did they balance the wheels with? the kind that sticks on like a sticker or the kind they hammer on to the wheel?
Old May 10, 2003 | 07:34 PM
phantom_sol's Avatar
Default Re: 70-80mph steering wheel shakes????help (superrally)
you might also want to do an all wheel alignment. maybe your toe-in is off or whatnot. i had toe problem and it wore the hell out of my tires till driverside popped. not fun. def check alignment imo
Old May 10, 2003 | 07:49 PM
BLUTO's Avatar
My civ was doing that too for a day or so when I would hit 70 mph, then it just stopped. Now it's back to normal. How long has this been going on?
Old May 10, 2003 | 08:42 PM
kommon_sense's Avatar
Default Re: 70-80mph steering wheel shakes????help (phantom_sol)
alignment problems usually show up through tire wear or twitchy handling. It shouldn't show up as a shaking steering wheel. When you cracked the rim, did you get everything else checked out as well? tie rods, axle, etc? Are your rotors warped? Are you sure that your tires are balanced correctly? Most shops offer warranties on their balancing.
Old May 10, 2003 | 08:46 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: 70-80mph steering wheel shakes????help (kommon_sense)
does it go away when you let off the gas? if so inner joints that are bad it will do that. start east. balance the tires at a good shop.
Old May 10, 2003 | 09:39 PM
creasian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superrally &raquo;</TD></TR><TR><TD CLASS="quote">could be front rotors are warped... what type of "weight" did they balance the wheels with? the kind that sticks on like a sticker or the kind they hammer on to the wheel?</TD></TR></TABLE>
i dont think it's the rotors, if it's the rotor it'll shake when he's braking, i'm pretty sure that big piece something fucked your alignment up.
hope that helps.
Old May 10, 2003 | 10:06 PM
i prefer the hammer ones so i got thoses
Old May 10, 2003 | 10:08 PM
oh yeah forgot to mention the day before i hit the big *** piece of **** i belw out both axles and a motor mount at the track, what a bad day that was
Old May 10, 2003 | 10:12 PM
Default Re: 70-80mph steering wheel shakes????help (boostedcivicsir)
i dont remember if it did or not cause i havent driven my car today cause i did a little tune up, but i think i'll go drive it right now, anyways im thinking its either the inner or outer tie rod, but im not sure, is there a way i can check it?
Old May 10, 2003 | 10:13 PM
oh yeah and about the tire balancing shop....i have been going to the same shop with the same guy for nearly 3 years and all of the other times i had my tires done there i had no problem at all, so i've kind of ruled that one out.
Old May 11, 2003 | 06:40 AM
95hbMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xhatchracerx &raquo;</TD></TR><TR><TD CLASS="quote">oh yeah and about the tire balancing shop....i have been going to the same shop with the same guy for nearly 3 years and all of the other times i had my tires done there i had no problem at all, so i've kind of ruled that one out.</TD></TR></TABLE>
I'd get them checked again cuz I had the same problem....I was rolling on my steelies and at 60-70 mph my steering wheel would shake bad..then when I got my rims put on I got them mounted and balanced and I can go 90+ smoothly, no shakes....
Old May 11, 2003 | 09:42 AM
Noe Kozz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">does it go away when you let off the gas? if so inner joints that are bad it will do that. start east. balance the tires at a good shop.</TD></TR></TABLE>
I'm having that same problem right now. I have to take my car to a frame shop, it's more than just my joints.
Old May 11, 2003 | 09:57 AM
kay_animation's Avatar
Default Re: 70-80mph steering wheel shakes????help (Noe Kozz)
I also have the same problem, around 75-80MPH. It did it before I lowered the car so its not the drop. I do know that the car was in an accident with the provious owner so it might be frame damage. Don't know what I need to do though. I guess I do need an alignment though.
Old May 11, 2003 | 10:58 AM
slvrcivic97's Avatar
Default Re: 70-80mph steering wheel shakes????help (kay_animation)
Alignment. The balance is off which is making it shake at those speeds.
Old May 12, 2003 | 07:12 PM
i recently drove my car through some familiar roads that i know that arent full of bumps and always had a smooth ride, well it turns out that the steering wheel shakes a little bit both on deceleration and acceleration.
Old May 12, 2003 | 07:13 PM
Audi RS4's Avatar
Lover
get an alignment, that took mine away..............
Old May 12, 2003 | 07:21 PM
turboD16's Avatar
did you say you got new tires too? if not it could be seperated tires.
Old May 12, 2003 | 07:26 PM
tonyxcom's Avatar
Default Re: 70-80mph steering wheel shakes????help (turboD16)
sounds like you some of you guys need hubcentric rings.
Old May 12, 2003 | 07:30 PM
i dont want to sound stupid but could you explain separated tires?? i did not get new tires because they are only 2 minths old
Old May 12, 2003 | 07:40 PM
Default Re: 70-80mph steering wheel shakes????help (AK1200)
yeah i was thinking of doing an alignment this week because its really beginning to annoy me and im not going to fix this problem unless i start somewhere. Besides the alignment shop should be able to tell me if my tie rods or shot then if not and the problem persists i am going to lean towards rebalancing my tires.
Old May 12, 2003 | 07:42 PM
tonyxcom's Avatar
what kind of wheels are you using? stock or aftermarket? exactly what kind?
Old May 12, 2003 | 07:49 PM
Default Re: 70-80mph steering wheel shakes????help (tonyXcom)
after i damaged my front right wheel i was unable to find a replacement because they were no longer in production, so i bought four new rims, rota circuit 8s
Old May 12, 2003 | 07:50 PM
tonyxcom's Avatar
Do you have little rings inside the rims to center them on your hub? My bet is that is your problem.
Old May 12, 2003 | 07:56 PM
what do you mean by little rings inside the rims? like where the bolt pattern is? i ask this because i dont know what to look for if i check, shouldnt new rims come with these little rings? i thought that the dome shape of the lug nuts centered the rim to the hub
