help..car idles then sputters..and then eeeww...smell of gas.
Old May 10, 2003 | 05:20 PM
BoOsTeD_eK's Avatar
Default help..car idles then sputters..and then eeeww...smell of gas.
I have a b16a hatch in a ek, wiring harness used was a 2000 si and nothing was chopped up or anything like that. Car will be idling and all of a sudden starts sputtering and chek engine light starts flashing. After a minute the smell of gasoline starts creeping its way into the car. there are no fuel leaks...is this a sign of a failing fuel pump or whats going on? The fuel pump in there is the stock hatchback pump with less than 25,000 miles on it. Also..I have not wired the second O2 sensor up, but the car was running fine b4 and never had any problems..so what could it be? ALL SUGGESTIONS ARE APPRECIATED!
Old May 10, 2003 | 08:48 PM
civicmatt's Avatar
Default Re: help..car idles then sputters..and then eeeww...smell of gas. (BoOsTeD_eK)
Check spark. You might have an unburned gas problem.
dephtone
24
May 17, 2011 05:19 AM
FJBB6
Oct 12, 2009 05:35 PM
ken hill
Mar 27, 2008 07:10 PM
Rbehne2
Honda Civic (2001 - 2005)
Nov 20, 2007 05:41 PM
civicgsr116
Nov 13, 2007 08:32 AM
