knocking noise on rear right side, help please
Old May 10, 2003 | 01:03 PM
lessthndan's Avatar
Default knocking noise on rear right side, help please
when i hit a bump it sounds like something is knocking against the car on the right rear side..a shop said i may have a weak spring...could that be hitting the strut or causing something to make that noise? what else could it be, it doesnt look like anything is bent or loose. thanks guys
Old May 10, 2003 | 01:05 PM
jonoknut's Avatar
Default Re: knocking noise on rear right side, help please (lessthndan)
i your car lowered? thats what mine sounbds like when i first dropped it without shocks or strusts, when i go over a bump it would make a knocking type noise, the shock was blown. hope that helps.
jon
Old May 10, 2003 | 04:13 PM
NeoGSR's Avatar
i got the same problem except it's in the front.....i've done axles/bearings etc...nothing seems to help so i'm guessing it's a blown shock or something messed with the suspension.....only does it when it's wet out though....strangest thing.....but the car handles/rides/sits just fine......lemme know what you find out
Old May 11, 2003 | 08:26 AM
lessthndan's Avatar
Default Re: knocking noise on rear right side, help please (NeoGSR)
Yes the car is lowered....i got a new strut for it but it still made the sound. I just bought a new pair of springs so when I put them in we'll see. The car didnt sit right on mine. The right side was higher then the rest. ill keep you posted. thanks guys
Old May 11, 2003 | 10:50 AM
The-LS's Avatar
ball joint(s)?
Old May 11, 2003 | 12:47 PM
lessthndan's Avatar
Default Re: knocking noise on rear right side, help please (Black-LS)
hmm can you give me more info on why it would be balljoint(s) and if that could be making a knocking sound. .anything will help. thanks
Old May 12, 2003 | 09:49 AM
JimBlake's Avatar
How about loose hangars for your exhaust? That's over on the right-rear. Get down there & take a look. Something hitting usually makes marks...
Stealth_Ek9
Jan 3, 2007 10:01 PM
smkngsr
Honda S2000
Feb 27, 2006 12:14 AM
972drcordex
Jan 11, 2004 08:47 PM
Slow
Dec 17, 2003 11:40 PM
SD_EM1
Mar 7, 2003 11:35 AM
