Axle seals leaking...which parts do I need?
I have leaks on my 94 LS Manual transmission where the axles enter on both sides.
On the diagram below which parts do i need to order to replace these seals and get rid of my leaks? t.i.a.
here is where one of the leaks is located.
yeah, that is where it is leaking...so 16 on that side. Thanks.
it is also leaking on the other side where the "intermediate shaft"?
goes into the transmission.
is there another picture that shows the other side and the part that i need...or are they the same parts for both sides?
thanks again.
goes into the transmission. is there another picture that shows the other side and the part that i need...or are they the same parts for both sides?
thanks again.
Would #17 in this diagram below be the other side that I need?
I am pretty sure it would be but want to double check. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie »</TD></TR><TR><TD CLASS="quote">If it is leaking where the screw driver is inserted you will need part#16 in the picture below.
yup, it's a cheap part and quite simple to install....i did one myself actually
</TD></TR></TABLE>yup, it's a cheap part and quite simple to install....i did one myself actually
