Holy Crap rebuild expensive!!!!
Old May 10, 2003 | 03:15 AM
Ottoman's Avatar
Default Holy Crap rebuild expensive!!!!
here's a price quote for parts they suggested for a d16a9 rebuild:
H090017-901-003/BOLT
H006110-P29-000/GASK
GASKET KIT,CYLN
PISTON SET (STD)
H013011-PM6-G01/RING
BRG, [BROWN]
BRNG, a MAIN
PULLEY, CRANKSHAFT
BELT,TIMING
H014510-PM7-003/TENS
FILTER, OIL
H016016-PM6-005/SCRE
H016176-P06-A01/GASK
PUMP COMP, WATER
THERMOSTAT ASSY
M022200-P29-020/DISK
H022300-P29-010/DISK
BEARING,CLUTCH
CORD COMP HI TE
KEY, PARALLEL
PLUG,SPARK (BKR6
OIL, ENG 20W50
TOTAL: 1083.21
Now I know why they call it a stealership...
man it doesn't look like much is left after a rebuild, or is this all over kill?
Old May 10, 2003 | 05:00 AM
94CivicSi's Avatar
Default Re: Holy Crap rebuild expensive!!!! (Ottoman)
You really need to go through the motor and see if you need parts like new pistons and bearings. That's high dollar stuff that you don't need to replace if the parts are still within spec. And a crankshaft pulley? Unless yours is damaged, that's not a part that you'd ever need to change.
Is there a reason you're rebuilding? Does the motor have a specific problem?
Old May 10, 2003 | 05:33 AM
.RJ's Avatar
.RJ
Default Re: Holy Crap rebuild expensive!!!! (94CivicSi)
dont need new bearings? you're kidding right.....
Old May 10, 2003 | 07:19 AM
owen_the_soyboy's Avatar
Default Re: Holy Crap rebuild expensive!!!! (.RJ)
call LEN at baranco acura/honda and I am sure he can get you better pricing.
he has a thread in the BEST BUYS forum.
and yep rebuilds cost money... mainly on bearings, oversize pistons and rings, new seals and refreshing parts like fuel injectors as well.
Old May 10, 2003 | 07:35 AM
TodaSi's Avatar
Default Re: Holy Crap rebuild expensive!!!! (owen_the_soyboy)
Dude, you have to go here!
http://www.importperformanceparts.net/
Old May 10, 2003 | 12:47 PM
Ottoman's Avatar
well the reason i thought i should rebuild was cuz i got challenged by another crx on the highway, he had better acceleration then me, till the top and we both topped out at about 210km/h with a flat distance between us...
he had a stock straw pipe exhaust, dunno what he had under the hood, he claimed nothin special...
sad thing is i have i/h/e might not be the best parts on the market, and my gear box might be worn but WTF...
FlashfmDB8
Aug 6, 2013 05:40 AM
type_r_ek
Jul 30, 2012 06:33 PM
redDAinteg
May 29, 2005 06:19 AM
mickeywickit
Sep 4, 2004 07:14 PM
