94+ GSR axles/intermidiate shaft w/b-series swap question
Old May 9, 2003 | 02:15 PM
Si-Yaaa!'s Avatar
Default 94+ GSR axles/intermidiate shaft w/b-series swap question
I'm getting a b18c1 swap minus the hydro tranny (unless it falls through), and read on hasports website that the 94+ gsr axles fit w/the 94+ intermidate shaft, but you have to change the intermidate shaft seal, and do the same mod as you do with the 90-93 integra axles. But when searching around on here, some people said you have to alter the hubs or spindles? Is it worth it to use the 94+ axles, or just buy some 90-93 integra axles? This would be used with the hasport mount kit and JDM YS-1 tranny. Thanks!
Old May 9, 2003 | 02:49 PM
ViperRedCRX's Avatar
Default Re: 94+ GSR axles/intermidiate shaft w/b-series swap question (Si-Yaaa!)
i want to know the same, but with a hydro tranny
Fobtions's Avatar
i have the 94+ axles setup it works fine with no modification other than the axle seal swap.
Old May 9, 2003 | 02:58 PM
Si-Yaaa!'s Avatar
Default Re: 94+ GSR axles/intermidiate shaft w/b-series swap question (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">i have the 94+ axles setup it works fine with no modification other than the axle seal swap. </TD></TR></TABLE>
Sweet, so they work. But what about the dust shield thing like on the 90-93 teggy axles? Not needed?
Old May 10, 2003 | 05:02 PM
Fobtions's Avatar
i still have em in. No binding at all. Im sure if you take em out itll be fine. As for the hydro tranny you dont need to swap the seal out , it comes with the right seal.
EF9*Hottie
13
Oct 25, 2007 07:06 AM
lilpastrana
Sep 6, 2007 07:30 AM
bboyPHOENIX
Jul 14, 2006 05:02 PM
HamiltonRex
Feb 22, 2006 03:58 AM
