Problem???? Please Help
Old May 9, 2003 | 02:07 PM
XzzYzzX's Avatar
Default Problem???? Please Help
I have 95 gsr in my 91 crx i put it in a couple months ago, i have been having problems wit the motor, like when i put it in first gear and rev well letting the clutch out it starts to putt and there is no power i have to shift to get power if i am in second and put it in third its does it. when i ran open headers its would putt all the way up to vtec then it goes back normal. I have a crack in my piping also my injectors have like 170,000 miles on them they are from my stock crx.... could i be conbustion problems?? Any ideas??? THanks for your help.
Old May 10, 2003 | 07:19 AM
XzzYzzX's Avatar
Default Re: Problem???? Please Help (XzzYzzX)
Anybody???
Old May 10, 2003 | 12:14 PM
XzzYzzX's Avatar
BuMp...
Old May 11, 2003 | 07:51 AM
XzzYzzX's Avatar
help......
Old May 11, 2003 | 10:10 AM
Timmah!!'s Avatar
I think the problem may be with you injectors. I dont have any experiance with B series swaps, but i think you need to be using the GSR (or other b series) injectors. I could be wrong so dont quote me on this.
Somebody back me up if thes is right.
Old May 12, 2003 | 11:08 AM
XzzYzzX's Avatar
Default Re: Problem???? Please Help (azroth)
Could anybody help....
Old May 13, 2003 | 02:26 PM
XzzYzzX's Avatar
bump...
Old May 13, 2003 | 03:01 PM
turboZChatch's Avatar
Injectors are the prolem
1) What did you do to use those injectors did u chang the clips on the harness or did you leave the si harness in the car
2) We did a swap into a 91 rex 95 gs-r the kid for some reasson had the si injectors out of his rex in the motor it ran like complete **** changed them to ls injectors and it fixed it change the injectors and get back to us
Old May 13, 2003 | 03:05 PM
ThatRicerDaniel's Avatar
is your all o2 correct?
Old May 14, 2003 | 07:15 AM
XzzYzzX's Avatar
Default Re: Problem???? Please Help (NitrousDreamz)
I used my stock crx si wire harness so i have gsr injecors but they don't fit in the harness so i used the si injectors.. they have 168,000 miles on them i have gsr injetors i will trade for LS ones but will LS ones fit on the si harness??? also wat year too???
Old May 14, 2003 | 09:14 AM
injectors pulse what the ecu tells it to.
welfarepc
Jul 15, 2011 08:29 AM
skate_volcom2006
Sep 1, 2008 10:09 PM
XzzYzzX
Oct 29, 2002 12:25 PM
lopey
Apr 15, 2002 10:28 AM
