jdm ITR SRS Wheel Q
Old May 9, 2003 | 10:56 AM
98R-1144's Avatar
Default jdm ITR SRS Wheel Q
The steering wheel I'm thinking about getting only comes with the wheel + airbag... nothing else.
Will the US reel (hub?) work with the JDM wheel? Or does the JDM wheel have to use the JDM one (what is it called by the way?)
Here is the part i'm referring to on the rear that didn't come w/my wheel...
http://ebay3.ipixmedia.com/abc...B.JPG
Old May 10, 2003 | 10:55 AM
CWITR's Avatar
Default Re: jdm ITR SRS Wheel Q (98R-1144)
as long as you get one that came off a JDM ITR, it is plug and play. I put mine on without any problems.
Old May 10, 2003 | 10:58 AM
skafia's Avatar
25 Year Member
Default Re: jdm ITR SRS Wheel Q (CWITR)
Your signals won't cancel correctly though, a little annoying, but well worth the bling.
Old May 10, 2003 | 11:37 AM
uncleben's Avatar
Default Re: jdm ITR SRS Wheel Q (skafia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skafia &raquo;</TD></TR><TR><TD CLASS="quote">Your signals won't cancel correctly though, a little annoying, but well worth the bling.</TD></TR></TABLE>
everyone have this problem?
Old May 10, 2003 | 01:36 PM
Saga's Avatar
That's because you did not align the spline with the signal canceller properly.
Old May 10, 2003 | 04:50 PM
98itR484's Avatar
Default Re: jdm ITR SRS Wheel Q (Saga)
everything will work as it does now. Just get everything in place and you should be good to go.
Old May 10, 2003 | 06:32 PM
machgo5go's Avatar
JDM position of alignment key pins on the signal cable reel is not same as USDM. U need to rotated away from the USDM factory Arrow mark at 12o'clock position inorder to accommodate JDM wheel. That is why your signal clicker return will be not working in one direction.
natman316
Apr 13, 2011 10:26 PM
slammed EG
Nov 22, 2005 08:53 PM
Flux
May 7, 2004 06:42 PM
CTR94Joes
Oct 30, 2003 03:52 PM
skafia
Jun 4, 2002 02:48 PM
