h22 swap in accord
ok this question is for you guys that have done an h22 swap into your accords. i dont have much experience with accords, but when you did your swap did you use your stock alternator, or did you use one off an h22? are they the same (i know obd1 and obd2 are different plugs) but is the alternator and the way it bolts up the same?
It does bolt up but you need to lengthen the wires cause the route of the wires on the F22 and the H22 are different so you need to add about 1 inch to it.
Accordhybrid
Accordhybrid
i had to use a power steering pump from a integra dont ask why the person helping me wit my swap did it i just suggest anyone doin a swap period make sure you have all the parts you need dont be like me and rush stuff it makes more headaches in the long run..........and also i had to buy a stock drivers side prelude motor mount cause my h22 didnt have one cause u need that mount and the rest stayed the stock accord mounts
RiceFed
Jan 9, 2006 07:28 AM
matix
Sep 25, 2003 06:18 AM
