How do i adjust my TPS
Old May 9, 2003 | 08:30 AM
JDMlyfestyle's Avatar
Default How do i adjust my TPS
my idle is completely jacked and i unplugged my tps and it was fine. so how do i adjust my TPS. or could it be my IACV
Old May 9, 2003 | 08:34 AM
137's Avatar
137
Default Re: How do i adjust my TPS (JDMlifestyle)
could be having an electrical problem with yours like I am mine... im going to swap mine with my brother this weekend
Old May 9, 2003 | 08:56 AM
your going to put your bro's sensors in your car?
Old May 9, 2003 | 09:07 AM
SloCivicHMM's Avatar
Default Re: (JDMlifestyle)
yup..I believe all b honda TPS are teh same...don't quote me but as far as d series go and b series you know.......obd1 and 2 I miean..
Old May 9, 2003 | 09:13 AM
137's Avatar
137
my brother has a jdm b16 im sure the sensor is the same we will see if it works if not i gotta tear down half of the electrical system and check all of my grounds so i can pin point the electrical problem in my car... ive never had a problem with this sensor before and i damn sure aint paying 300 bucks to get a new one if my old one isnt broken.
Old May 9, 2003 | 09:22 AM
Default Re: (137)
werd!!
I need to adjust mine..>I took my TB off a while ago...how is this done??
Old May 9, 2003 | 09:23 AM
I have a funky idle...could be my IACV but I cleaned it.....I'm going to try to adjust my TPS....if not my dizzy is going bad...
Old May 9, 2003 | 11:21 AM
I got my MSD Cap in and blaster coil. i installed them and my idle is fine now. check your ohm readings on your coil it should be 12 ohms mine was at 7.8 ohm and honda said that will mess up your idle
Old May 11, 2003 | 02:20 PM
thanks...I shall do that....I have the MSD stuff laying around...
But my rotor screw on the dizzy is stripped....
Old May 11, 2003 | 03:39 PM
NiiS's Avatar
Default Re: How do i adjust my TPS (SlowCivicHmm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowCivicHmm &raquo;</TD></TR><TR><TD CLASS="quote">...if not my dizzy is going bad...</TD></TR></TABLE>
....if you had a bad distributor, it simply would`nt work. I`m not thinking that`s your problem.
Old May 11, 2003 | 05:35 PM
drunknbass's Avatar
Default Re: How do i adjust my TPS (sinister)
plug a voltomiter into the red wire (99% sure) and ground and it should read .5 at idle and 4.5 at wot
hadehatch
Dec 4, 2024 01:46 PM
Tizzakowack
Dec 12, 2008 02:06 PM
kootari
Feb 10, 2007 04:07 PM
alupso
17
Apr 18, 2006 07:21 PM
98gsrTEG
Apr 17, 2004 11:12 AM
