OBD2 -> OBD1 harness
I'm kinda curious.
Are the plugs on an OBD2+ say GSR ECU the same as those of an OBD2+ Prelude ecu? (can I use an OBD2.2 -OBD1 harness from a GSR on a P13 in my 5g prelude?)
Which version of OBD does the 5th Gen have, OBD2 or OBD2.2 ?
Thanks
Thanks
Only the 96-98 Integra OBD2->OBD1 harness will work. They are the same as the 97+ Prelude. But then Integra harnesses changed after 98.
There is no such thing as "OBD2.2" It's either OBD1 or OBD2. Those are the only 2 diagnostic specs mandated by the federal government to date.
Andrew
Andrew
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18onboost »</TD></TR><TR><TD CLASS="quote">
1996-1998: OBD2A
1999-2000: OBD2B
Does that apply to all hondas? thx
1996-1998: OBD2A
1999-2000: OBD2B
1996-1998: OBD2A
1999-2000: OBD2B
100% pure BS. The EPA has regulations that mandate the impementation and governing of only 2 automotive on board diagnostic specs to date. They are OBD1 and OBD2. I think that you may be confused because the Integra ECU design changed in 1999+. But all 1996+ ECUs are simply OBD2 compliant. There is no more advanced OBD spec than 2... yet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Damn noob</TD></TR></TABLE>
"b18onboost has been a member for 294 days."
"aklucsarits has been a member for 661 days."
Indeed.
Andrew
Modified by aklucsarits at 4:27 PM 5/15/2003
1996-1998: OBD2A
1999-2000: OBD2B
Indeed.
Andrew
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aklucsarits »</TD></TR><TR><TD CLASS="quote">
Indeed.
Andrew</TD></TR></TABLE>
lol... own3d!!!
Indeed.
lol... own3d!!!
http://hondata.com/adapters.html
then why does every one sell two different types of OBD2 adapters?
The hondata site even gives pictures of them being different. from 97 to 98
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lildrgn »</TD></TR><TR><TD CLASS="quote">http://hondata.com/adapters.html
Because the board design and plug type of B series ECUs is different between 96-98 and 99+. It was probably done as a cost-cutting move to make the ECUs cheaper to produce. But they both have exactly the same functionality. The newer ECU design adds no new monitoring or functionality to the engine control however.
Andrew
Andrew
oh.. ok.. this whole thread kinda went OT then..
the original question was about the plugs being the same..
I know that there is no other type of OBD... the a and b are just different adapter plugs..
Guest
Posts: n/a
I cant believe they make you a moderator. I guess my dog can apply for admin then. Lol</TD></TR></TABLE>
oh, i didn't apply jackass, they gave me the posistion for a reason, Andrew and i both know that your are wrong about what OBD2 and ODB3
did ou now that technically ALL OBD2 ECUs were supoosed to have Flash PROM editing like the new RSX??? yeah, you probably didn't know that, ayways, you amde a good thread go to ****
NOman0608
Jul 26, 2007 10:28 AM
Civic98KH
Mar 11, 2007 09:21 PM
B18Redline
Feb 16, 2007 07:20 AM
all but ASE certified, no ****, i didn't make it up, governments says all new cars produced after 2010 will be OBD3, some GM cars may even have it by 2007
