88 CRX rear swaybar
Old May 8, 2003 | 09:24 PM
sciolist's Avatar
Default 88 CRX rear swaybar
I'm in the process of upgrading the stock suspension with Tein SS and an ES master kit.
I have to swap on 89+ rear LCA's to make the coilovers work which will mean a new rear swaybar. (88 connects to LCA's, 89+ connects to dampers).
Any recommendations on a new rear swaybar?
Thanks
Old May 9, 2003 | 07:20 AM
sciolist's Avatar
Default Re: 88 CRX rear swaybar (sciolist)
What about running it without the rear swaybar entirely? Is that going to induce oversteer or just make it sloppy?
TIA
Old May 9, 2003 | 08:14 AM
untitled's Avatar
i have a 88 rear sway bar if you want it.
Old May 9, 2003 | 08:23 AM
sciolist's Avatar
Default Re: 88 CRX rear swaybar (88crx91integra)
I have an 88 too, that's the problem. I have to swap the LCA's and the swaybar will no longer bolt up.
Old May 9, 2003 | 09:01 AM
Flexmyrex's Avatar
get a rear sway bar for 89 from suspension techniques and leave the stock on up front
Old May 9, 2003 | 09:35 AM
sciolist's Avatar
Default Re: 88 CRX rear swaybar (flexmyREX)
Hey Flex:
Will that bolt right up to the dampers or do I need extra hardware, bushings, etc?
Thanks
bobby_da6
Sep 10, 2008 05:23 PM
atc5
21
Nov 29, 2005 10:16 PM
EF8 JUNKIE9
Apr 13, 2005 09:15 PM
ACRXGuy
Feb 27, 2003 07:49 AM
Civic44
Jul 8, 2002 06:15 AM
