B18b Power Steering
Im going to be swaping in a b18b into a 93 ex and was wondering about power steering.
1) What is needed to make it compatable with the LS engine?
2) What is needed to just take it completely out?
Thanks
Thanks
1) you dont need power stearing, if you have arms like a 8 year old then maby you do but......
2)follow all the lines that go from the power stearing pump and remove whatever they connect to. ( thats what i would do)
1) Amuse me, I plan on autox so im sure it couldnt hurt.
2)I guess I should of been more specific... but after I take off the obvious pump and lines what do I replace it with? I've heard of a bracket or something.
It depends on what year B18B you get 96 + have a larger opening than the 95 and below. I have a 98 Civic EX and had to cut and weld an older fitting to make the power sterring work.
and for anyone who tells you you don't need power steering unless you are a *****...**** em...Its nice to have a little luxury in a civic.
streetspeed
10
Apr 9, 2003 04:53 AM
