How to turn off ABS?
Old May 8, 2003 | 11:42 AM
dynamo's Avatar
Default How to turn off ABS?
The car is a 1994 Honda Accord, and since no one can tell what's going on in this post:
https://honda-tech.com/zerothread?id=499141
I was wondering if someone could tell me how to turn off ABS all together and see if that fixes the problem, at least intermittently.
TIA
Old May 8, 2003 | 12:00 PM
Stripped Honda's Avatar
99-0104
Default Re: How to turn off ABS? (dynamo)
pull the abs fuse ?? i just cant see how the abs can cause the other problems tho....
Old May 8, 2003 | 12:20 PM
Chiovnidca's Avatar
Default Re: How to turn off ABS? (Stripped Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stripped Honda &raquo;</TD></TR><TR><TD CLASS="quote">pull the abs fuse ?? i just cant see how the abs can cause the other problems tho.... </TD></TR></TABLE>
Yea, pull out the fuses in the ABS fuse box.
Old May 8, 2003 | 12:30 PM
dynamo's Avatar
Where is the ABS fuse located?
Also, I agree, it's doubtful that the rest of the problems such as the speedo shutting on and off for a split second is probably not caused by the ASB problem (although I know for a fact that there is a problem with ABS due to the symptoms prior to the speedo problem taking place). Someone told me to check for corrosion on the battery clamps, so I will be replacing those tonight to see if it fixes anything.
Old May 8, 2003 | 07:28 PM
haccord2.2's Avatar
It is located on the passanger side under the hood on the front side of the shock/strut tower. All you have to do is take out the one Main ABS Fuse (I think it is green with a clear top if I remember right and a 30 or 40 Amp Fuse) which is screwed down by two screws. I have done this to my abs once when My ABS Unit went Bad.
Whatislove
Honda Civic (2001 - 2005)
Aug 29, 2009 08:35 PM
eurowned
Dec 3, 2007 03:05 PM
cslegacy
Sep 11, 2007 03:36 AM
vti444
Sep 6, 2004 12:44 PM
