Attn all people w/ aftermarket ignition
Old Jul 6, 2001 | 10:08 AM
blackls's Avatar
Default Attn all people w/ aftermarket ignition
Where the **** did you mount your ignition amp? I tried mounting it on the firewall behind the intake manifold, but after driving for 5 minutes, the thing was sooooo hot...and then I felt my intake manifold and I realized why; the amp was absorbing heat from the manifold as well. I want to mount it inside, but I'm not sure on how to run the wires through the firewall. Any help you guys could give would be helpful; thanks.
Old Jul 6, 2001 | 10:50 AM
bigTom's Avatar
Default Re: Attn all people w/ aftermarket ignition (blackls)
lol... this is the only pic i can find where u can vaguely see it... its mounted right next to the battery... to the right of it... basically on it... its the silver sci ignition btw
Old Jul 6, 2001 | 10:51 AM
bigTom's Avatar
Default Re: Attn all people w/ aftermarket ignition (4dr-gsr)
amp u were saying? if u mean the coil... thats on the bottom left of the picture... on the frame... the redish type thing (its a crane )
Old Jul 6, 2001 | 11:10 AM
berkel's Avatar
Hey,
I have a Four Door too
Mine is also on the battery, but on top. I have a Honda Goldwing battery though, so there's room.
FB
Old Jul 6, 2001 | 11:38 AM
martilafox's Avatar
New User
Default Re: Attn all people w/ aftermarket ignition (berkel)
I've seen it mounted underneath the driver's side seat!! i didn't think the wires would extended that much, but i guess they do . . .
Old Jul 6, 2001 | 11:39 AM
martilafox's Avatar
New User
Default Re: Attn all people w/ aftermarket ignition (cdelro)
oops..just realized..it was the ignition not the amp i was referring to. . oh well, forget the last post.
Old Jul 31, 2001 | 06:42 AM
Slick GS-R's Avatar
how about my MSD Digital 6AL install along with my MSD Blaster SS Coil with custom bracketry. The Zex N20 box as well with the custom bracket.
Here is a link to all of the pix:
[Modified by Slick_GS-R, 12:20 AM 8/1/2001]
Old Jul 31, 2001 | 07:35 AM
WOTTEG's Avatar
If you are referring to the rectangular red box tath is about 8" by 5" by 2", Put it behind teh stereo console, between your gas pedal and the passenger side foot area. If you decide to drill though, be very careful not to drill through stuff on the other side!
Old Jul 31, 2001 | 08:13 AM
Rhetoric's Avatar
I have a msd sci and it has been mounted behind my intake manifold for over a year already with no problems. The blaster coil is ghetto tie wrapped to my abs.
Old Jul 31, 2001 | 11:07 AM
MintyDip's Avatar
Default Re: Attn all people w/ aftermarket ignition (G S R)
I have my MSD 6al int he front seat passenger side under the carpet. I'll try to take some pictures this weekend.
Old Jul 31, 2001 | 02:07 PM
DB2-R81's Avatar
25 Year Member
Default Re: Attn all people w/ aftermarket ignition (MintyDip)
MintyDip got it right, under the passenger seat. No heat, no H2O, no UV sunlight, easy to isolate from vibration, out sight from thieves, protected from physical damage..... The engine compartment is not the place for it, only back yard mechanics that don't know any better mount them near the engine. Have a look at any true racecar that depends on reliable you won't find an ignition amplifier in the engine compartment. You know where mine is!
[Modified by DB1-R81, 3:18 PM 7/31/2001]
95bkeg
Jul 24, 2006 06:39 PM
tnsxsear1
10
Dec 3, 2003 06:31 AM
Wiseguy619
Oct 17, 2003 09:33 AM
ITR1299PR
May 14, 2003 04:36 AM
wutangben
Apr 30, 2003 11:47 AM
