pullin a code 16
Old May 8, 2003 | 05:50 AM
shadowstylz's Avatar
Default pullin a code 16
Umm I belive Im doing this right I turned the key all the way untill right before I cant turn it any more before starting it. Then I loook at my ecu and it I keep on counting how long it was blinkin and damn I must have counted a hundred blinkin lights, so I said wait a minute are they the same code flashing over and over? and sure enough each one of them blinked 16times and stoped. then 16 times and stoped, so did I read it right?
I searched on this forum and found out that code 16 is Fuel Injector System defective circuit or unplugged / defective fuel injector.... so how do I fix this ? I recently altered the intake with a filter, is this what caused the problem? Some time my car idles a little high and some time it is hunting for a idle point... Can some body please post ur comments to help me out...
Thanks in advance.
Old May 8, 2003 | 06:33 AM
Default Re: pullin a code 16 (shadowstylz)
will somebody please help?
Old May 8, 2003 | 06:36 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
is one of your injectors unplugged? does it run really rough?
try resetting the ECU just to make sure its not a fluke. and if the check engine light comes back on see if its the same code.
when i got a 16 one of my injectors was barely unplugged...it looked plugged in but wasnt.
Old May 8, 2003 | 06:55 AM
USDM 4G VTEC's Avatar
Default Re: pullin a code 16 (fastcrxsi90)
on my case it was a fracture on the #1 injector cable..... cable was barely broken and didnt noticed.... u cut soldered a new cable and worked fine.... check ur wiring.... also u can check all the injectors... by using a ohmeter between the two pins on the injector itself.... should be 1.5-3.5 ohms..... if more than that the injector its fried....
Old May 8, 2003 | 05:38 PM
Default Re: pullin a code 16 (USDM 4G VTEC)
I found out I was reading that red light wrong so I gotta watch it again, and see what codes it pullin.
Will the code keep on showin, or will it evr stop?
Old May 8, 2003 | 05:47 PM
FourthGenHatch's Avatar
The code thing should repeat and repeat for a long long time, possibly forever, and by forever I mean until you ran out of batteries, but that would be almost forever.
Old May 8, 2003 | 07:52 PM
Foowee's Avatar
Default Re: pullin a code 16 (FourthGenHatch)
I've seen a code 16 for a faulty main relay. also just because it's clicking doesn't mean it's working. You may want to resolder the joints just for to be safe.
WhiteSOHC
Mar 21, 2011 03:31 AM
NATEDEEZY
Jan 6, 2008 11:13 AM
Dspad_91Civic
15
Jul 9, 2004 12:07 PM
theharlequin
Apr 13, 2004 03:23 PM
JStone2775
Oct 29, 2002 07:22 PM
