Stock 1/4 on type s and ep3
Guest
Posts: n/a
Hi i am thinking about getting a RSX type s. wanna know what a stock 1/4 mile time is on one. i seen in car and driver they had it a 16.3 is this true if so thats shitty. I had a GSR that pulled 14.7 and i loved it and i just want another clean good car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacnGsR »</TD></TR><TR><TD CLASS="quote">Hi i am thinking about getting a RSX type s. wanna know what a stock 1/4 mile time is on one. i seen in car and driver they had it a 16.3 is this true if so thats shitty. I had a GSR that pulled 14.7 and i loved it and i just want another clean good car.
That sounds like a base RSX time.
I have seen worser times then that when S.C.C. tested a base, rsx, and civic si. The type S was quoted as running a 16.7. It all depends on the driver bro, and in that case the driver of those car should have been beaten. I hit a 15.oo when my car was stock. The type S is a good car and the motor is amazing. It has only been out a while and there is loads of aftermarket parts available for it.
Good luck bro.
Good luck bro.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoodKnight »</TD></TR><TR><TD CLASS="quote">
That sounds like a base RSX time.</TD></TR></TABLE>
Base & automatic @ that which is the slowest of the RSXs. Unless someone bogged a launch badly with a 5-speed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch2k »</TD></TR><TR><TD CLASS="quote">The best times I've heard for EP3 in stock (including crappy tires) are high 15's. Probably from very good or very lucky drivers.</TD></TR></TABLE>
I'll have to say that's quite accurate. If it was any slower, it might as well share times with a regular Civic.
I would be with the... its about the driver and the car. I went 15.6@86 with my ep3. And that was the weekend after i got it. It had 500 miles on it... Now im pulling about 15.0 I would say(went 15.2@90 with shitty tires). And thats just intake and testpipe. And with the hondata, top end is no longer a problem. They are both good cars... If you can afford type s, get it! If not, the SI is a nice compromise. Good luck with whatever you pursue, but make sure its a Honda!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk02EP »</TD></TR><TR><TD CLASS="quote">If you throw some kumhos, falkens, or any other decent tires on the EP stock, than you should hit around 15.7-15.8. And a regular Ex runs around 16.4 or so. </TD></TR></TABLE>
Don't ever call kumho's decent tires... especially for drag racing. Kumho's are teh suck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B-Series »</TD></TR><TR><TD CLASS="quote">
EX can run low 16s with a good driver, but yeah. Most people who've posted slips that I've seen have gotten in the mid 16s - bleh.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedBlueEM2 »</TD></TR><TR><TD CLASS="quote">
What do you run in your EX? My friend has a 2k1 EX with I/E ran a best of 16.5@85 mph, but with a horrible 2.55x 60 ft time....
</TD></TR></TABLE>What do you run in your EX? My friend has a 2k1 EX with I/E ran a best of 16.5@85 mph, but with a horrible 2.55x 60 ft time....
I ran a 14.9 against 30 mph headwind and -2.0 negative front camber with my jic's set for autox on azenis w/ intake and exhaust, so I'm guessing a 15 isn't far fetched but about 15.1 - 15.3 ish
quickest EP i have seen (bone stock) went 15.6
quickest rsx-s i have seen went 14.9 with only a cai
and quickest base rsx(cai, cat back) i have seen ran a 16.0 but at 3000ft altitude ( thats like a 15.6-.7 run at a lower track....
OneThirtyEight
30
Sep 14, 2001 06:50 PM
