f/s: 2000 Itr complet top end and more......
Old Jul 6, 2001 | 07:11 AM
b18c1_powered_si's Avatar
Default f/s: 2000 Itr complet top end and more......
off 2000 itr with 8k complete head,valve train,cams,valve cover,all sensors,injectors,fuel rail,intake manifold,throttle body all nuts and bolts $1855shipped
2000 itr ecu immoblizer removed $300shipped
2000 itr axles/intermediate shaft $345shipped
2000 itr radiator/both fans $185shipped
2000 itr starter $85shipped
2000 itr alternator $85shipped
1997 jdm itr cluster 42k $355shipped
94 gsr obd1 stock usdm ecu $355shipped
95 del sol dohcvtec distributor obd1 $300shipped
95 del sol head 48k $550shipped
96 jdm gsr valve cover $85shipped
bosch racing fuel external pump $80shipped
pressure plate and clutch disc ACT extreme off a 2000 itr with 7k on it. lots of life on it $225shipped
2000 itr flywheel $110shipped
2000 itr distributor $275shipped
2000 si distributor $255shipped
96 gsr ecu $205shipped
2000 itr a/c compressor $75shipped
[Modified by b18c1_powered_si, 8:11 AM 7/6/2001]
Old Jul 6, 2001 | 07:30 PM
Default Re: f/s: 2000 Itr complet top end and more...... (b18c1_powered_si)
itr flywheel was sold 10:45am 7-6-01.
Old Jul 14, 2001 | 03:24 AM
the ecu,head,alternator and starter is gone!
Old Jul 14, 2001 | 01:06 PM
owen_the_soyboy's Avatar
what makes the JDM 97 ITR cluster different from the 94 GSr cluster.. I want a different cluster...
your is in kph I assume?
any differences other than that?
redline? needle colors?
thanks.
Old Jul 15, 2001 | 03:44 AM
stick's Avatar
Default Re: f/s: 2000 Itr complet top end and more...... (owen_the_soyboy)
just like the USDM cluster except in KM/h
and yellow needles
jmagic
Jun 17, 2003 10:33 AM
b18c1_powered_si
Jul 6, 2001 07:26 PM
