knocking noise from the driver side;in engine bay
Old May 7, 2003 | 09:33 PM
1320sLEEper's Avatar
Default knocking noise from the driver side;in engine bay
at times i here noise when i rev hi and decelerate in the same gear. when the car jerks a little i here the noise. but at times i here it when i am just startin off slow in first gear or when i downshift...i just had the timeing belt put in and a tentioner and a water pump....the new **** came from a type:.....> are brand new parts<.....
..... .someone please try to help me figure this out......o and how can u tell if your crankshaft in messed up in anyway.... Thanks .....
Old May 7, 2003 | 09:54 PM
MikeSarr_GSR's Avatar
Default Re: knocking noise from the driver side;in engine bay (1320sLEEper)
ouch bro. this dont sound good for you. drain the oil pan, then dump the contents into a bottle. take the pan and inspect it in the sun, if you see a powdery glitter or small flakes of brass... or metal of any kind... do NOT drive the car. TOW it to a mechanic and have the bearings inspected right away. thats my advice to you.
Old May 9, 2003 | 01:12 PM
Default Re: knocking noise from the driver side;in engine bay (MikeSarr_GSR)
so u think it could be the bearings! hmm....when i drained the oil before it looked good ...but i dont here that noise all the time tho u think it could still be the bearings????hmmmmmm....
Old May 9, 2003 | 11:24 PM
im giving you suggestions. for all I know you could have a marble in your engine.
Kouki_crumbs
Honda Civic (2001 - 2005)
Jan 14, 2017 04:51 PM
MADBADGER
Honda S2000
Jul 14, 2008 09:33 AM
saturn78
Apr 2, 2007 03:11 PM
