Secondary Intake Runners
Old Jul 6, 2001 | 05:52 AM
Dawsonb17a's Avatar
New User
Default Secondary Intake Runners
Everyone's talking about how the change in sound you actually hear in the B18C1 engine at high rpm are the secondary intake runners opening up, not VTEC that engages at 4400rpm. I've heard that not all the DOHC VTEC engines have that, is this true? I've got a B17A1 engine, and was curious if I've got that secondary intake runner thingy.
Old Jul 6, 2001 | 06:11 AM
Gman96gsr's Avatar
Default Re: Secondary Intake Runners (Dawsonb17a)
I don't think the B17A had the secondaries. I know the B16A and B18C5 don't have it. The Prelude VTEC engines might have it, but I'm not sure.
Old Jul 6, 2001 | 06:27 AM
Dawsonb17a's Avatar
New User
Default Re: Secondary Intake Runners (Gman96gsr)
I have a low restriction intake and exhaust right now ( meaning loud) so as soon as I hit 5500-5700 (hard to tell with tach) my engine sounds like the fury of God. What is causing that noise if the VTEC engages at 4400rpm? I've heard 3rd Gen GS-R's and Type R's make a similar noise at autoxes. My dad has a '98 Prelude too, and his H22A makes a noise starting around 5700rpm that is similar, if a bit more muffled in his stock car. I always thought it was the VTEC, can someone shed light on this?
Old Jul 6, 2001 | 06:59 AM
eg6ajk's Avatar
92-3 B17A = b16A with a stroker kit to 1.7...that's all, vtec switchover on a P61 ecu, is roughly 5.7k rpm...therefore what you hear is vtec, switch the cams to high out put mode....
in b18c (GSR) motor, vtec switchover occurs at 4.4k and 5.7k secondaries switch off to high flow mode...
Old Jul 6, 2001 | 07:08 AM
Dawsonb17a's Avatar
New User
Default Re: Secondary Intake Runners (eg6ajk)
Thanks for the enlightenment
Old Jul 6, 2001 | 08:54 AM
H23 Power's Avatar
the Prelude 92-96 SI and 93+ VTEC have the secondary runners also...
and the 01+ TL and CL Type S
Masho
Honda Civic (2001 - 2005)
16
Jun 5, 2010 03:34 PM
superfrk
Jan 11, 2007 09:56 PM
salman
62
Sep 11, 2006 04:25 AM
elpiar
Apr 19, 2006 07:33 AM
2KFBPgsr
Mar 20, 2003 11:25 PM
