Chaning Tranny Fluid
Old May 7, 2003 | 05:14 PM
DrunkNRacer's Avatar
Default Chaning Tranny Fluid
I have to change this girls tranny fluid for her.. Its a 94 accord ex *AUTO* ...
Ive never changed tranny fluid before.. I know its a simple process of drain and fill.. But i was wondering about flushing the entire tranny through.. what exactly do i do? Just Refill it with some crappy fluid.. run the car for a lil bit.. and drain it.. and refill with the good stuff?
Another questions is: "Is there a big difference between Honda Auto Fluid.. and some other brand?"
Old May 7, 2003 | 07:45 PM
Default Re: Chaning Tranny Fluid (G-villeRacer)
Bump it up
Old May 7, 2003 | 08:06 PM
Stripped Honda's Avatar
99-0104
dont use crappy fluid use only honda ATF and if it has been a long time sence she changed it do it 3 times and it will be pretty clean
Old May 8, 2003 | 10:10 AM
YeuEmMaiMai's Avatar
if you want the entire tranny flushed:
1. find a honda dealer that will do it (rare)
2. Jiffy Lube (the route I took) and make sure they add a bottle of Lube Guard.
This is what I usually do
Follow the manual service recommendations and at 100K flush the entire tranny so far ever (knock on wood) had an automatic fail every single one has lasted the life of the car
1989 mercury sable auto tranny still good at 196K when 3.8l blew a head gasket
1992 mercury sable auto tranny still good when car was totalled at 143 K
1992 mercury sable auto tranny still good car has 126K
1994 Honda accord LX 105K auto tranny still good
Of course I am not nuetral dropping it either
When you do a drain and fill at most you will get about 1/3 of the fluid most often you get about 1/5 to 1/4
Old May 8, 2003 | 10:50 AM
Default Re: Chaning Tranny Fluid (YeuEmMaiMai)
I just finished it today... It Gobbled down 4 bottles of Honda ATF ... wow! I was told 3 .... it seems like there is even more room.. I filled it through ATF dipstick.. this is correct right??
Old May 8, 2003 | 11:35 AM
crafty's Avatar
I have a 94 and the dealer told me 4...
It only took 3 and I filled mine through the dipstick hole
Old May 8, 2003 | 11:45 AM
Default Re: Chaning Tranny Fluid (crafty)
sounds like you didnt let it drain thoroughly... I did 4 and still had some room
slatermvp
Apr 13, 2012 04:17 PM
ragnarok0mega
Aug 1, 2010 06:32 AM
greenskittle
May 14, 2010 12:05 AM
ShockerLude89
May 17, 2004 05:18 PM
