what brand of brake fluid should i use?
Old Jul 6, 2001 | 12:31 AM
Lei Siew Long's Avatar
Default what brand of brake fluid should i use?
as stated in a previous post, up next in the braking category will be a set of powerslot rotors and project mu brake pads. would like to know what brand is good and would be good for this setup as well. thanks in advance.
Old Jul 6, 2001 | 12:33 AM
Default Re: what brand of brake fluid should i use? (boostedeg6)
oh yeah, when changing the brake fluid, do i have to bleed the entire system or is there an easier way. thanks again.
Old Jul 6, 2001 | 10:00 AM
EminemGSR's Avatar
You should bleed the entire system if your fluid is dirty, or you dontt change it regularly. The best fluid to use is Honda or Ford DOT 3 or DOT 4 fluid. Everyone says such great things about Motul, but if you're not going to the track w/ your car, don't bother with it. It's meant for higher temps, and not for everyday street driving.
Old Jul 6, 2001 | 10:16 AM
Crack Monkey's Avatar
Motul 600, Ford Heavy Duty, ATE SuperBlue or ATE Type 200 (same fluid, different colors), Castrol SRF.
The Ford is the cheapest. The Castrol is expensive. The ATE and Motul are in the middle. The nice thing about the ATE is you can alternate colors, so you can easily tell when system is bled.
I use Motul or ATE in my race and street cars.
The Ford has the lowest wet boiling point of the above, meaning it needs more frequent bleeding. The Castrol SRF has the highest wet boil point, explaining its high cost. The Motul is 2nd best. The ATE is third, but still way better than the Ford.
If you're car never see the track, the Ford is a good choice. Be sure to ask for the Heavy Duty fluid - the regular stuff is not nearly as good.
Old Jul 6, 2001 | 03:40 PM
miketegra's Avatar
Default Re: what brand of brake fluid should i use? (Crack Monkey)
CrackMonkey - great info !
I use Honda -buy at least 3 bottles if you plan to do a full flush.
Old Jul 6, 2001 | 04:45 PM
Default Re: what brand of brake fluid should i use? (miketegra)
great info guys. i appreciate the help. as for the motul, if i did a full flush, how many bottles of the 5.1 would i need? on inlinefour.com's website, it says that i can mix it with other synthetic brake fluids. i plan to frequent the tracks during the weekends so, this might be the stuff i want to use. pretty expensive at $10 a bottle.
FireMedic
Jan 24, 2005 12:47 AM
kommon_sense
Jan 4, 2005 11:46 AM
CivicSiRacer
24
May 15, 2003 12:03 PM
totaled
Feb 12, 2003 11:16 AM
turbotypeR@SPEC
Dec 11, 2002 03:42 PM
