what stock seats fit into an ek?
Old May 7, 2003 | 02:13 PM
Wazup's Avatar
Default what stock seats fit into an ek?
i hate my seats and was wondering what other stock seats fit into my civic. i want the eg seats but i heard they dont fit. any others?
Old May 7, 2003 | 02:16 PM
lazy bum shaughn's Avatar
Default Re: what stock seats fit into an ek? (Wazup)
What stock seats fit in your car? Stock S2000 seats can fit in your EK. Stock NSX seats can fit in your EK. Stock Integra seats can fit in your EK.
It all depends on how much modifications you want to go to make the seats fit properly.
Old May 7, 2003 | 02:17 PM
HXMan's Avatar
Yea, it seems to me EKs don't have any nice choices for seats that bolt right in. Integra seats will bolt right into EGs.
Unless you like the 99-00 Si seats..I think they suck ***. Might as well keep your stock ones if that is the only choice.
Wazup's Avatar
Default Re: what stock seats fit into an ek? (lazy bum shaughn)
thanks, but what about the eg seats? will they fit with their stock rails?
Old May 7, 2003 | 02:21 PM
Kid1320's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wazup &raquo;</TD></TR><TR><TD CLASS="quote">thanks, but what about the eg seats? will they fit with their stock rails?</TD></TR></TABLE>
yup but only 3 bolts will bolt up
Old May 7, 2003 | 02:34 PM
tonyxcom's Avatar
Default Re: what stock seats fit into an ek? (Kid1320)
You can bolt any DC/EG seats/rails into an EK by notching the end of the rail to allow a bolt like in this picture. I later added a rectangle steel washer to help reinforce it.
Old May 7, 2003 | 03:01 PM
leprechan117's Avatar
Default Re: what stock seats fit into an ek? (tonyXcom)
so integra seats bolt right into eg's?? nice....
Old May 7, 2003 | 03:04 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom &raquo;</TD></TR><TR><TD CLASS="quote">You can bolt any DC/EG seats/rails into an EK by notching the end of the rail to allow a bolt like in this picture. I later added a rectangle steel washer to help reinforce it.
So leather GSR seats will bolt into a EK with the same mod?
Old May 7, 2003 | 03:05 PM
Kid1320's Avatar
Default Re: what stock seats fit into an ek? (1 point 6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 point 6 &raquo;</TD></TR><TR><TD CLASS="quote">
So leather GSR seats will bolt into a EK with the same mod?</TD></TR></TABLE>
yes
Old May 7, 2003 | 03:32 PM
tonyxcom's Avatar
And the best part is that the seats sit over an inch lower... which may or may not be a good thing depending on how tall you are.
Old May 7, 2003 | 03:36 PM
pdiggitydogg's Avatar
why not just change the rails from the ek seats to whatever you get (ie dc seats)? Wouldnt that solve the problem??
Old May 7, 2003 | 03:53 PM
tonyxcom's Avatar
Default Re: what stock seats fit into an ek? (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">why not just change the rails from the ek seats to whatever you get (ie dc seats)? Wouldnt that solve the problem??</TD></TR></TABLE>
Because I am 6 feet tall and the lower my seat the better.
Old May 7, 2003 | 03:57 PM
EL-Driver's Avatar
The main key is the rails from your ORIGINAL EK Seats...
You have to swap those rails onto your new seats for them to bolt in..
With EG seats..basically install your EK seat rails onto the EG rails..
But I think you should look into Integra Cloth Seats, those are much better than the EG seats.
Old May 7, 2003 | 04:09 PM
tonyxcom's Avatar
Default Re: what stock seats fit into an ek? (EL-Driver)
I think we cleared that up a few posts above.
Old May 7, 2003 | 04:34 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Sometimes its not just a "lets swap the rails" It gets more involved in some cases with welding. Some OEM seats you have to break the rivets off to pull the tracks apart and switch them around.
I put Del Sol seats in my 91 civic hatch and i had to the whole switch and weld thing. So i dont want anyone to think this is just a bolt off/bolt on affair.
Please consult your local Honda-Tech reprsenenative for more information.
Old May 7, 2003 | 04:40 PM
VTEC-DA's Avatar
What about rear seats? Will the OEM DC2 rear seats bolt in? Are there any fitment problems except the gap on the one side?
Old May 7, 2003 | 04:45 PM
oldB18EF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 point 6 &raquo;</TD></TR><TR><TD CLASS="quote">Sometimes its not just a "lets swap the rails" It gets more involved in some cases with welding. Some OEM seats you have to break the rivets off to pull the tracks apart and switch them around.
Please consult your local Honda-Tech reprsenenative for more information. </TD></TR></TABLE>
it is a swap procedure going from eg/ek/integra
Old May 7, 2003 | 04:46 PM
tonyxcom's Avatar
Default Re: what stock seats fit into an ek? (VTEC-DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC-DA &raquo;</TD></TR><TR><TD CLASS="quote">What about rear seats? Will the OEM DC2 rear seats bolt in? Are there any fitment problems except the gap on the one side?</TD></TR></TABLE>
Check the forsale thread in my sig.
nevermind, items sold.
Modified by tonyXcom at 10:39 AM 5/8/2003
Old May 7, 2003 | 04:53 PM
rainmanEK's Avatar
big strong guy
You need to Switch The Inner Seat Rails from The EK stock seats to the 92-95 Civic or 94-01 Integra Seats!
And they will Bolt in!
All 4 bolts
Eric
Old May 7, 2003 | 11:03 PM
Wazup's Avatar
cant see the pic..
Old May 8, 2003 | 04:12 AM
Tiamat-blue's Avatar
what about prelude seats? Into an Ek.
Old May 8, 2003 | 09:38 AM
VTEC-DA's Avatar
Check the forsale thread in my sig.</TD></TR></TABLE>
There is nothing in your sig.
Old May 8, 2003 | 09:39 AM
tonyxcom's Avatar
because It was sold
Old May 8, 2003 | 05:55 PM
VRD^don's Avatar
stock ek fit in EKs
Old May 8, 2003 | 05:58 PM
Ricey McRicerton's Avatar
Default Re: what stock seats fit into an ek? (Tiamat-blue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tiamat-blue &raquo;</TD></TR><TR><TD CLASS="quote">what about prelude seats? Into an Ek.</TD></TR></TABLE>
Nope...not without cutting and welding the brackets...I had gotten some 92 Lude seats and didn't want to destroy the rails, so they wouldnt work. If you dont mind welding you could make it work. Good luck!
