failed emission (:<) rubbing alcohol help?
Old May 7, 2003 | 02:11 PM
neoburi's Avatar
Default failed emission (:<) rubbing alcohol help?
hey,
i live in wa, and today i failed that f... easy test..
my hc(ppm), co% on cruise emissions were 210 and 2.36 while passing is 160 and 1.1.. and on idle, i got 213/220 0.46/1.2
can anybody explain my problem?
and, does the rubbing alcohol trick can help me? (it did when i got rx7)
any reply will be very appreciated!!
Old May 7, 2003 | 02:18 PM
Blaze45's Avatar
Brrraaaap!
Default Re: failed emission (:<) rubbing alcohol help? (neoburi)
If you dont have a DX then you can unplug one of the injectors.... I herd peeps do that. About a half an hour of revin can clean out carbon deposits. Make sure that you have a 02 that can help as well. Never herd of the rubbing alcohol. Anyone care to post?
Blaze
Old May 7, 2003 | 02:22 PM
neoburi's Avatar
Default Re: failed emission (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">If you dont have a DX then you can unplug one of the injectors.... I herd peeps do that. About a half an hour of revin can clean out carbon deposits. Make sure that you have a 02 that can help as well. Never herd of the rubbing alcohol. Anyone care to post?
Blaze</TD></TR></TABLE>
thanks, but unfortunately, i have a dx with b16a.. with p30..
anyone?
Old May 7, 2003 | 02:27 PM
spettinger's Avatar
Default Re: failed emission (neoburi)
a p30 ecu? in what year car?
Old May 7, 2003 | 02:37 PM
neoburi's Avatar
Default Re: failed emission (2ndhandCRX)
88 dx hatch..
b16a with p30ecu..
i bought the car about 2weeks ago,
and after some tlc, it runs very good... except the damn emission..
Old May 7, 2003 | 03:00 PM
chad174's Avatar
then unplug one of your injectors. He meant any car with multi-point fuel injections. Un plug one injector and make it look like its still plugged in. Good luck.
Old May 7, 2003 | 03:07 PM
neoburi's Avatar
Default Re: failed emission (chad174)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad174 &raquo;</TD></TR><TR><TD CLASS="quote">then unplug one of your injectors. He meant any car with multi-point fuel injections. Un plug one injector and make it look like its still plugged in. Good luck.</TD></TR></TABLE>
so, go to emission center, and unplug one injector in the parking lot, and it should be looked like plugged on?
correct?
i think blaze meant that unplug one injector, 1 2/1 hour revin, then it will remove the carbon deposit..
confused.. anyway rubbing alcohol doesnt work on honda?
Old May 8, 2003 | 09:05 PM
neoburi's Avatar
come on guys..
what the hell is wrong with my cruise emission test?
what should i do!!!
just try some rubbing alcohol?
Old May 8, 2003 | 09:37 PM
andrew dc's Avatar
Default Re: (neoburi)
iso heet is your friend
ahobbs
Jul 14, 2008 09:38 PM
zerodiesel
Jan 21, 2008 05:29 AM
akstunt600
Jun 2, 2006 05:55 PM
Slomo_civic
Sep 8, 2005 09:10 AM
Kawaiii3oi
Jun 18, 2003 06:46 PM
