Wheel spacers to stop rubbing woes?
I am running Mugen Lowdowns, 16" MF10's +50mm and 215/45/16 Azenis. I have slight rubbing at full lock and want to eliminate the rub. I searched, but didn't find anyone else running spacers with my setup.
Will 5mm spacers be enough to stop my rubbing woes?
I have exactly this setup. There is slight rubbing a full lock. However, full lock is only going to occur at < 2mph so it is really not an issue. I would forget about it.
[Clarification: I meant the inital setup - not with the spacers.]
I have 225/40-16 tires on the same rims. i only have MINOR rubbing at full lock - so it rubs a bit - who gives a ****?
how often do you drive at full lock??
I was rubbing a little with my 205/50/15 v700s (EG w/ ITR suspension) and I ...(actually SPiFF) picked up some 5mm spacers from OPM.
Now, no rubbing and I haven't had any problems with the spacers. If you don't like the rubbing, get some spacers, I did (and would again).
5mm spacers should take care of your problem. 16x7 +45 offset wheels with the azenis that you have present no clearance isssues. If you cant live with the slight rub, get the spacers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R »</TD></TR><TR><TD CLASS="quote">I have 225/40-16 tires on the same rims. i only have MINOR rubbing at full lock - so it rubs a bit - who gives a ****?
how often do you drive at full lock??</TD></TR></TABLE>
Well, its not only at full lock, its also when I'm taking hard turns. I don't just drive on the street, but I autoX too. Oops. I guess I should have mentioned that first.\
Looks like I'll be getting the spacers then.. Should help get the car back to handling the way I like it too.. The Azenis are so sticky that I have a hard time getting the rear of the car to come around like it used to with 205/45/16 PZeros.
AamirCWITR
Aug 6, 2004 10:14 AM
