compatible exhausts for crx (other stock honda's fit?)
Old May 7, 2003 | 01:10 PM
PhatHardy's Avatar
Default compatible exhausts for crx (other stock honda's fit?)
I need the entire piping and muffler for a crx. What kind of piping will work, other than just a stock crx, i need to hurry cause the junk yard closes soon. Thanks guys If the muffler won't work but the piping will, that's ok too. THanks a lot.
Old May 7, 2003 | 02:15 PM
G2turbo_terror's Avatar
Default Re: compatible exhausts for crx (PhatHardy)
Someone correct me if I'm wrong but I believe that the B pipe is shared among 4th gens or just the hb/sedan...I guess just get under there and meassure as much as you can so if you were to find something you'd know if it'd work. I think the back half of DA exhausts will fit but its possiably to wide.
Old May 7, 2003 | 02:17 PM
PhatHardy's Avatar
Default Re: compatible exhausts for crx (G2turbo_terror)
which one is the b pipe?
Old May 7, 2003 | 02:43 PM
spettinger's Avatar
the crx mid section is seven inches shorter than the hatchback.
time to go to midas.
wfocrx
Mar 28, 2015 01:55 PM
gcturismo
Dec 2, 2007 02:48 PM
Jdm EF9
Nov 17, 2005 08:09 PM
B2FiNiTY
Mar 9, 2004 06:36 PM
RCautoworks
Nov 3, 2003 01:26 AM
