any problems running b16 head b18c block w/jdm b16a2 pistons?
Old May 7, 2003 | 11:09 AM
Nice_Dc2r's Avatar
Default any problems running b16 head b18c block w/jdm b16a2 pistons?
are there any problems running b16 head b18c block w/jdm b16a2 pistons?
valve clearance
journal
will this be a well balanced set up for daily driving
what would the compression be
would the rod ratio be unchanged
is it a direct fit
anyone have experience with this set-up or any dyno numbers
thanks in advance
Old May 7, 2003 | 11:14 AM
Katman's Avatar
Default Re: any problems running b16 head b18c block w/jdm b16a2 pistons? (nice_eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nice_eg &raquo;</TD></TR><TR><TD CLASS="quote">are there any problems running b16 head b18c block w/jdm b16a2 pistons?
valve clearance
journal
is it a direct fit
thanks in advance
Nope, you shouldn't have any clearance issues. The B16 pistons are a direct fit onto the B18C rods and will easily fit a B18C block, depending on if you're going OS or STD size pistons.
Your CR should be around 10.8-11.1 range, perfect, imo.
Your rod ratio will be unchanged, since you're not changing the B18C crank or rods. A piston change alone, will not affect rod ratio.
What camshafts are you planning to use ?
Old May 7, 2003 | 01:39 PM
Nice_Dc2r's Avatar
Default Re: any problems running b16 head b18c block w/jdm b16a2 pistons? (Katman)
i plan on using a high lift cam. leaning towards toda spec b's right now.
will there be any clearance issues with a high lift cam?
Old May 7, 2003 | 03:13 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nice_eg &raquo;</TD></TR><TR><TD CLASS="quote">i plan on using a high lift cam. leaning towards toda spec b's right now.
will there be any clearance issues with a high lift cam?</TD></TR></TABLE>
with spec b's you *might* run into clearance issues if you adjust the sprockets too far, but there's plenty of lee-way in comparison to CTR pistons (for instance) which those pistons create clearance issues.
Old May 7, 2003 | 03:29 PM
sgT's Avatar
sgT
havent really had any clearance issues with ctr pistons either...
Old May 8, 2003 | 10:10 AM
Katman's Avatar
Default Re: any problems running b16 head b18c block w/jdm b16a2 pistons? (sgT)
....wonderful.
there you have it, nice_eg.
hndacord02
May 11, 2007 07:09 AM
SkeeRX
Jan 6, 2006 07:06 PM
Dammit_Dan_954
May 13, 2004 04:43 PM
S2KP
Oct 23, 2003 09:05 PM
TedR719
Jun 30, 2003 11:20 AM
