A good a/f ratio gauge
Hey whats up guys. I have a couple of questions:
How many wires are our stock o2 sensors ( upstream o2 sensors)? and should I get an auto meter a/f ratio gauge.
Second: What other gauges are better for monitering the ratio other than the Greddy unit, and if I use the Greddy unit, Do I have to weld the O2 they supply or replace it with my stock upstream???
Thanks for the help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightkid13 »</TD></TR><TR><TD CLASS="quote">and should I get an auto meter a/f ratio gauge.</TD></TR></TABLE>
Their only good for display...
We need to have a sticky on this. YOUR STOCK O2 SENSOR SUCKS AT TELLING WHAT THE A/F RATIO IS!!!! only a wide band o2 sensor can do this. your stock will read 1v if the ratio is more than 14.7:1 and will read 0v if the ratio is less than 14.7:1. Thus it will read lean or rich, nothing else. not how lean or how rich.
Prelude is a 4 wire, btw.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 57STS »</TD></TR><TR><TD CLASS="quote">We need to have a sticky on this. YOUR STOCK O2 SENSOR SUCKS AT TELLING WHAT THE A/F RATIO IS!!!! only a wide band o2 sensor can do this. your stock will read 1v if the ratio is more than 14.7:1 and will read 0v if the ratio is less than 14.7:1. Thus it will read lean or rich, nothing else. not how lean or how rich.
Prelude is a 4 wire, btw. </TD></TR></TABLE>
Are you sure? Is this true?
If it is, I'm getting a wide band O2 kit for sure!
GQ 05YellowEVO8
Feb 2, 2002 07:46 PM
