on freeway, 5th gear, going to neutral without pressing on clutch?!?
Old May 7, 2003 | 09:32 AM
weakGOODJunKieS.com's Avatar
Default on freeway, 5th gear, going to neutral without pressing on clutch?!?
i was on the freeway in 5th gear and then i went into Neutral on accident without pressing the clutch... is something wrong? or is this normal.
Old May 7, 2003 | 11:09 AM
JimBlake's Avatar
Default Re: on freeway, 5th gear, going to neutral without pressing on clutch?!? (FrostWhiteDC4)
Did it pop out by itself or did you shift it? If it popped out by itself then I'd think of bad synchros, bent shift linkage, bent shift fork, ???
If you shifted it out, then no big deal. All you did is give it just enough gas so the engine's EXACTLY just keeping up. When there's no pressure on the gearset, then it slips right out of gear.
Old May 7, 2003 | 12:03 PM
Default Re: on freeway, 5th gear, going to neutral without pressing on clutch?!? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Did it pop out by itself or did you shift it? If it popped out by itself then I'd think of bad synchros, bent shift linkage, bent shift fork, ???
i pulled it into neutral on accident. i hand was on the **** and i was thinking about changing lanes then i noticed my hand pull it into neutral and engine rev without pressing the clutch. then i just cluched and put it back into gear and it was fine.
Old May 7, 2003 | 12:05 PM
PoW3l2BaN's Avatar
its normal....all gears can be moved into neutral without pressing the clutch when you are decelerating. 5th is the easiest one.
Old May 7, 2003 | 12:09 PM
Default Re: on freeway, 5th gear, going to neutral without pressing on clutch?!? (PoW3l2BaN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PoW3l2BaN &raquo;</TD></TR><TR><TD CLASS="quote">its normal....all gears can be moved into neutral without pressing the clutch when you are decelerating. 5th is the easiest one.</TD></TR></TABLE>
thanks! i dont have to worry about it being a problem, but i wont do that again.
Old May 7, 2003 | 01:30 PM
AWD: Jeff's Avatar
is it bad doing this while driving around,
ex: shifting gears without using the clutch, but no grinding sound. is this bad?
Old May 7, 2003 | 01:33 PM
Goldfingiz's Avatar
If you're good enough, you can shift any car without using the clutch. I've done it myself several times. Mess up, and it could be your tranny though
Old May 7, 2003 | 02:34 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: on freeway, 5th gear, going to neutral without pressing on clutch?!? (Goldfingiz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Goldfingiz &raquo;</TD></TR><TR><TD CLASS="quote">
If you're good enough, you can shift any car without using the clutch. I've done it myself several times. Mess up, and it could be your tranny though </TD></TR></TABLE>
"...granny shifting, not double clutching like you should have..."
Stan
Old May 8, 2003 | 05:19 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrostWhiteDC4 &raquo;</TD></TR><TR><TD CLASS="quote">thanks! i dont have to worry about it being a problem, but i wont do that again.</TD></TR></TABLE>
What you really shouldn't be doing is resting you hand on the shift lever. Unless you enjoy replacing shift forks...
Old May 8, 2003 | 06:05 AM
What you really shouldn't be doing is resting you hand on the shift lever. Unless you enjoy replacing shift forks...</TD></TR></TABLE>
what are shift forks?
Old May 8, 2003 | 06:11 AM
b19coupe's Avatar
Shift forks are the little thingys is the transmission that attach to hubs which slide up and down the main and countershafts to engage different gears.
Old May 8, 2003 | 06:14 AM
Default Re: on freeway, 5th gear, going to neutral without pressing on clutch?!? (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Shift forks are the little thingys is the transmission that attach to hubs which slide up and down the main and countershafts to engage different gears.</TD></TR></TABLE>
got it, thanks.
Ef4doorwagon
Nov 28, 2014 10:17 PM
ateeb786
Nov 6, 2006 07:15 PM
trianglegreg
Jan 4, 2006 03:13 PM
b20civic
Apr 14, 2003 12:43 PM
