MPFI question need help ASAP!!
Old May 7, 2003 | 08:31 AM
AGPSuperstar's Avatar
Default MPFI question need help ASAP!!
when the diagram said that pins b10 and b12 suppposed to be empty but it looks like b12 has something in it....does anyone else have this??
Old May 7, 2003 | 08:57 AM
xci_ed6's Avatar
Default Re: MPFI question need help ASAP!! (AGPSuperstar)
I had this as well, removing the wire that is already @ b12 gave no problems.
-Dustin
Old May 7, 2003 | 11:27 AM
FourthGenHatch's Avatar
Default Re: MPFI question need help ASAP!! (Autocratic_1st_Gen)
I don't think you need to remove that B12 then, you basically just need to fill up the correct spots with a wire so you can cut/add to it. Just leave it there.
DX had some sensors and stuff the Si/ZC doesn't have, so I figure the extra wires go to that stuff.
Old May 7, 2003 | 11:34 AM
Urban Business
Guest
Posts: n/a
Default Re: MPFI question need help ASAP!! (FourthGenHatch)
that may be for the tandem valve which will no longer be used. also some wires may be for ac. feel free to cut them if you dont have ac
Old May 7, 2003 | 02:34 PM
civickiller's Avatar
Default Re: MPFI question need help ASAP!! (limoZeen)
yeah mine had a wire there, i just took a pin from b2 and stuck it in b10. i just cut the wire at b12 and spliced in the wire needed
**** i hope that b12 wire is not for ac because my car has ac and i need it
Old May 7, 2003 | 02:38 PM
Default Re: MPFI question need help ASAP!! (civickiller)
yea i cut b11....they say its supposed to be for nothing and i hope that's not for a /c....i dont think b12 is for ac....it's one of the sensors on the dizzy i think
Camilo Mejia
Oct 21, 2018 12:51 PM
b20bIntegra
Mar 26, 2013 01:25 PM
ivan93egreppin210
Jun 19, 2010 02:15 PM
19992civichatch
Apr 1, 2008 09:42 PM
175Shot4Door
Apr 13, 2006 03:42 PM
