Dist. on mini me
Old May 7, 2003 | 07:26 AM
soundman's Avatar
Default Dist. on mini me
Yes I searched. On a D16A6 with a z6 head, what distributor should I use, then what mods do I need to do to make that distributor work?
Old May 7, 2003 | 07:42 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: Dist. on mini me (soundman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundman &raquo;</TD></TR><TR><TD CLASS="quote">Yes I searched. On a D16A6 with a z6 head, what distributor should I use, then what mods do I need to do to make that distributor work?</TD></TR></TABLE>
either z6 dizzy with obd1 conversion...or
a6 dizzy with a slight jimmy-rig.
Old May 7, 2003 | 08:28 AM
4drEF's Avatar
Keyboard Humorist
What ECU are you going to use? I guess you are going to use the 88~91 PM6 (Si or EX - non automatic)? You have to match the distibutor to the ECU. So, with the 88~91 ECU you will use the 88~91 distributor.
Put the distributor in the head. You will immediately notice that it does not bolt in. You have to modify the "ears" by cutting notches in them. This will allow you to set the timing correctly. I can't remember which side (toward front of car or rear) you need to notch, but I'm sure you can do a search and find out.
You can also DO an OBD-0 to OBD-1 conversion and use a P28 from a 92~95 Si. This will require some more work, but you will be able to use the 92~95 Si distributor that bolts right on to that head with no modding required.
Old May 8, 2003 | 05:32 AM
soundman's Avatar
If I did an OBO-0 to OBD-1 conversion, would I have to convert my entire wire harness, or is there a special wire harness conversion kit that I could put onto my existing harness that wouls allow me to plug the Z6 computer into my harness?
Old May 8, 2003 | 06:38 AM
Default Re: (soundman)
i think hasport makes a harness. but check around for better prices.
Randysi
49
Oct 30, 2011 09:54 PM
posaccord01
Mar 22, 2007 03:59 PM
Bense
Jan 8, 2006 12:02 PM
Sirex
Mar 18, 2003 07:31 PM
vtecrx
Nov 8, 2002 05:18 PM
