STR intake manifold question?
i just installed my str intake manifold but i left my stock gsr Throttle body on it, can the stock throttle body have any effect on how my manifold works or performence? Because my car stalls a bit when i floor my car from a downshift (4G-2G WOT)
G"s indicate gears
wot = wide open throttle
G"s indicate gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STR »</TD></TR><TR><TD CLASS="quote">Is the car N/A or FI?</TD></TR></TABLE>
I would guess he is FI from his user name!
TB definately effectshow the IM performs. Since your turbo, I say go bigger. In all motor apps, I've read; Big IM plenum, small TB diameter. Small IM plenum, larger TB diameter. I don't know if this is completly true, but that was the only refernece by a writer to this matter and the writer is very knowledgable.
Yes go to a bigger TB!! Only if you are F/I, though.
That manifold is massive and needs more air. If you are running a small *** TB, the manifold isn't getting enough air. Run something like a 70mm.
B18c1-Integra
13
Feb 22, 2008 05:34 PM
Turbo R
33
Apr 15, 2005 11:28 PM
