axles arnt working??????
Old May 6, 2003 | 03:47 PM
durrett syndrome's Avatar
Default axles arnt working??????
ok zc tranny and motor and zc int. shaft.....axles fit with no pin but wen i try to put them in with the pin they wont fit in.i tried usign grases and everythign adn wont go in. they did go in all the way wen i had no pin. wat is there to do....
already tried searching....
Old May 6, 2003 | 04:18 PM
SIRX's Avatar
Default Re: axles arnt working?????? (durrett syndrome)
I don't understand what you mean by "pin" post a pic. as long as your using 90-93 teg axles you shouldn't have a problem. Sometimes you have to remove the dust-seal on the hubs but that is usually it. Use this pic and show me what you are talking about. These are the right shafts to use.
Old May 6, 2003 | 05:46 PM
Default Re: axles arnt working?????? (SIRX)
yea i got those axles. teh "pin" im talking about is the circular ring kinda liek a piston ring that goes around the end of the axle. it goes into the hub fine just not the tranny adn 1/2 shaft. thanks
Old May 6, 2003 | 06:41 PM
SIRX's Avatar
oh the axle retaining clip. It sometimes can be a PITA to get the axles to snap in. They should go. Just give them a little presuasion
d16a9_edcivic
Jul 18, 2008 05:51 PM
GroundZer0 336
13
Sep 27, 2006 10:41 PM
Rob!
12
Nov 14, 2002 07:14 PM
MugenGTR
Jul 24, 2002 08:43 AM
kokujin
Apr 11, 2002 06:50 AM
