Received my MPFI stuff....any precautions or advice for a fellow??
Old May 6, 2003 | 12:08 PM
AGPSuperstar's Avatar
Default Received my MPFI stuff....any precautions or advice for a fellow??
well...just received all my MPFI stuff in the mail today. i have all the information on how to swap everything but do i need to know other things related to it?? any help would be greatly appreciated...thanks agp
Old May 6, 2003 | 12:51 PM
Aron Parsons's Avatar
Default Re: Received my MPFI stuff....any precautions or advice for a fellow?? (AGPSuperstar)
Replace all gaskets and seals (including injector o-rings, seats, etc).
Clean everything out while it's off the car (inside the manifold, throttle body).
Make sure you have every single nut and bolt you'll need for the swap.
Run voltage tests on the sensors to ensure they're working.
Buy a Helm's manual if you don't already have one. This way, if a problem arises, you can actually fix it.
Old May 6, 2003 | 01:02 PM
-16V-'s Avatar
Default Re: Received my MPFI stuff....any precautions or advice for a fellow?? (Aron Parsons)
A man im on the same boat your on....
I just need to get me a si dizzy and im set, then after that im going to boost my mpfi dx.....
Hope every thing works out...
Old May 6, 2003 | 07:03 PM
91civicEX's Avatar
Run all your wires before you actually do the swap. make sure you have all the tools you need. dont forget to drain the coolant. scrape ALL the gasket off the new manifold. make sure you either have a beater car or a ride to get emergency parts. Check to see if you manifold is complete and remember that none of your old parts will bolt on.
Eskiee
Honda Civic (2006 - 2015)
Nov 22, 2013 07:43 AM
Abandoned Ship
Texas -OK -LA (Sales)
17
Feb 3, 2008 07:26 PM
asianalpha
Jul 26, 2004 07:00 PM
hondacivic4g
Oct 19, 2003 12:20 AM
Hayasa15
13
Mar 9, 2002 08:38 AM
