Hybrid Supercharged K24-R dyno results
Old May 5, 2003 | 10:32 PM
Hondata's Avatar
Default Hybrid Supercharged K24-R dyno results
In the best traditions of squeezing the finest of Honda's parts bin into a Civic, we are pleased to bring you:
This was not an exercise in power, but one to extract maximum torque.
Specifications:
Accord 2.4 bottom end (9.5:1 compression)
RSX-S head
Japanese Integra Type R camchafts
RC 550 saturated injectors
RSX-S six speed gearbox
Jackson Racing race headers and test pipe
Short ram intake
5 Zigen catback
Stock fuel pump and stock fuel pressure
Driving Impressions
This would have to be the most fun Honda I have driven. Flexing your right foot instantly delivers weapons grade torque and leaves you grabbing for the next gear. Most freeway onramps will have you well into three digits before you have to merge. This engine does not need to be redlined for a fast getaway though. Huge amounts of torque mean that corners normally negotiated in second gear can be taken in 4th or fifth. You can change from first gear to sixth with no hesitation. For long interstate trips sixth gear would be all you need for 80-120 mph cruising.
Thanks to Hasport for supplying the car and engine and to Jackson Racing for supplying and fitting the supercharger. Hasport sell a stiffer rear motor mount for this car which is needed to reduce engine movement under acceleration.
Check out http://www.hondata.com/dynok24rvsk24rsc.html
and http://www.hondata.com/dynok20rvsk24r.html
for more information.
Old May 5, 2003 | 11:07 PM
SlammedBlueEM2's Avatar
Default Re: Hybrid Supercharged K24-R dyno results (Hondata)
Maybe I should reconsider that K20 swap...
Old May 5, 2003 | 11:51 PM
DC5-R's Avatar
very nice doug.
Old May 6, 2003 | 01:01 AM
NA gs-R 05 C
Guest
Posts: n/a
Default Re: Hybrid Supercharged K24-R dyno results (DC5-R)
those are some sweet #'s.
Old May 6, 2003 | 01:46 AM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
holy crap. if this motor was in the hasport EP3 @ supr2nr honda/nissan battled, i would've easily had FTD!!!
Old May 6, 2003 | 06:09 AM
Big Money D's Avatar
Default Re: Hybrid Supercharged K24-R dyno results (GhettoRacer)
that is sick
Old May 6, 2003 | 06:42 AM
Josh02Si's Avatar
Default Re: Hybrid Supercharged K24-R dyno results (George Knighton)
About how much money is involved to make something like that?
Old May 6, 2003 | 06:53 AM
1abSi's Avatar
Default Re: Hybrid Supercharged K24-R dyno results (Josh02Si)
<----reaches for credit card
Old May 6, 2003 | 08:40 AM
chunky's Avatar
isn't the k24 accord bottom end 9.7:1 compression, as per honda official website?
or does the type-s head have a larger bowl volume dropping the CR to 9.5:1?
Old May 6, 2003 | 10:00 AM
SMZ GSR's Avatar
Default Re: (chunky)
wow, people already making crazy frankenstein k series motors. good job
Old May 6, 2003 | 10:52 AM
Boost Ambassador's Avatar
Nice job guy.
BOING!
Old May 6, 2003 | 11:04 AM
JUN JDM's Avatar
sWEEt #'s..............
Old May 6, 2003 | 11:18 AM
illi Adik's Avatar
Old May 6, 2003 | 12:07 PM
ilovemyhonda's Avatar
Default Re: Hybrid Supercharged K24-R dyno results (Jackson4Door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jackson4Door &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Old May 6, 2003 | 12:47 PM
ep3minivan's Avatar
Default Re: Hybrid Supercharged K24-R dyno results (ilovemyhonda)
Hondata.
Old May 7, 2003 | 06:41 PM
chunky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunky &raquo;</TD></TR><TR><TD CLASS="quote">isn't the k24 accord bottom end 9.7:1 compression, as per honda official website?
or does the type-s head have a larger bowl volume dropping the CR to 9.5:1?</TD></TR></TABLE>
so is there gonna be an official hondata reply to my question?
Old May 7, 2003 | 07:02 PM
Joker's Avatar
You've got my attention
Old May 7, 2003 | 07:04 PM
f1nal zeros's Avatar
Default Re: (Joker)
Well holy sheep ****!!! LOL..
Nice numbers guys, the car looks like a beast.
Old May 7, 2003 | 07:27 PM
PaX's Avatar
PaX
I noticed that they used the stock fuel pump and pressure. , did they use a return line system with this also?
Old May 8, 2003 | 06:26 AM
Hondata's Avatar
The compresion ratio was not measured as the heads were not CC'. 9.7:1 could be closer to the compression ratio. I was quoting from memory when I typed 9.5.
No return line was used. As a result the installation was very clean and easy.
Cost of the Accord block (a wrecked engine) was about $2000-2500.
Donor RSX-S engine and gearbox - unknown
Injectors about $360.
Supercharger - unknown as they are not for sale yet.
Old May 9, 2003 | 06:46 PM
skud_dusty's Avatar
Default Re: (Hondata)
damn...thats just sick
Old May 9, 2003 | 11:45 PM
K20A2-t's Avatar
sick numbers, hondata rules!!
Old May 9, 2003 | 11:47 PM
R you serious's Avatar
man i hope i can get a ride in that thing when hasport gets it back hasport
Old May 10, 2003 | 05:53 AM
HybridFiend's Avatar
Default Re: Hybrid Supercharged K24-R dyno results (R you serious)
Goes to show...$$$ makes the world go round!
Old May 13, 2003 | 01:33 AM
freud's Avatar
hrmmm... where'd the plot and web pages go?
