Anyone have pic's/info/part # of bearing puller needed for tranny rebuild?
Like the title says, I'm trying to track down exactly what I'm going to need to replace the bearings on my ZC tranny.
I'm going to get:
Snap ring pliers
Bearing puller (need info)
Anything else I will need other than simple comon hand tools?
Any advice as to how to dissasemble the tranny would be great! I have a very good Idea of what I need to do, but then again, I have never done this my self. What would be the best way to tackle this without causing something to break/lose parts/and save time (from those who have done it before)?
Thanks for any help!
I'm getting my Quaife and rebuild kit this friday!
I'm going to get:
Snap ring pliers
Having rebuilt many trannies the best advice I can give you is to take alot of pictures while you are disassembling the tranny. Also have alot of room. there are alot of pieces inside the tranny. everything should come apart easily. Do not force anything.
I say take the case to a shop and have them pull the bearings for you... It will save you a lot of headaches and it will be cheaper than buying the tools required
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thumpu77 »</TD></TR><TR><TD CLASS="quote">I say take the case to a shop and have them pull the bearings for you... It will save you a lot of headaches and it will be cheaper than buying the tools required</TD></TR></TABLE>
ditto! there are only 2 bearings that i couldn't pull out...they are the mainshaft and countershaft bearings that are inside the clutch housing. it cost me $10 to get them pulled and it was well worth it.
