picked up a gsr block lookin to build it up looking 4 sum input (all motor)
im basically using my crank which was still good from my b18c5 in my gsr block which i just picked after my b18c5 exploded im thinking of using using the ctr pistons on the gsr rods . Or should I go aftermarket. Im not looking to sleeve the block. Im still goona be using my b16 head w/ skunk internals including stage 2 cams . What kind of #'s will i be looking at in a 91 si hatch
ctr pistons, jun stg3 cams with fully upgraded valetrain, stroke the motor with b20 crank and bore it over a little. eagle rods are good and there pretty cheap. use skunk2 high comp valves. you might have clearence issues.
well i got my skunks and i was very happy w/ them my head is all skunk and salvageable. I was thinking of using the ctr's w/ standard bore on gsr rods. What do u guys think
broketuner-Sol_Si
39
Apr 13, 2006 06:37 PM
