Easy How To:Keep your shift boot up
Old May 5, 2003 | 06:47 PM
TerribleOne's Avatar
Default Easy How To:Keep your shift boot up
I bought a new **** recently and there was a gap between the boot and the ****, I could'nt glue it cause in reverse and 1st or 5th it would put to much pressure on it and would always break apart so I went ot my local hardware store and bought a little rubber plug making sure that the top and bottom fit pretty much flush with teh boot and ****. I drilled a hole through the plug and shaved off some of the bottom with a knife to make it easier to work the boot on, then I just screwed the **** on and voila! Enough space for the boot not to stretch and no more little gap with the shifter arm showing, Im pleased and it only cost me 44 cents!
Old May 5, 2003 | 06:48 PM
Default Re: Easy How To:Keep your shift boot up (TerribleOne)
forgot to do email notification...double post sorry
Old May 5, 2003 | 06:49 PM
vtecdc2's Avatar
just take the boot off, and put a zip tie from the bottom side. it will hold the boot up also..
Old May 5, 2003 | 06:52 PM
smallttocs's Avatar
Default Re: Easy How To:Keep your shift boot up (VTECDC2)
i just use viagra to keep it up
Old May 5, 2003 | 06:59 PM
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECDC2 &raquo;</TD></TR><TR><TD CLASS="quote">just take the boot off, and put a zip tie from the bottom side. it will hold the boot up also..</TD></TR></TABLE>
same thing I did, but with electrical tape....lol.
Just take the boot off after you find how far the shift **** sits, then wrap some electrical tape around the shifter, drop over the boot(the top of the boot will stay up from the lip and the tape)....and you're good to go.
I just don't like the look of the rubber.....good DIY though
Old May 5, 2003 | 07:01 PM
BauleyCivic's Avatar
Risky Business
Default Re: Easy How To:Keep your shift boot up (Emerika)
i like my si **** and boot...they clip together
Old May 5, 2003 | 07:07 PM
Default Re: Easy How To:Keep your shift boot up (BauleyCivic)
Yea just another way to do it, I like the way the rubber looks and how it grips to the boot instead of just sitting against the metal, just another way to do it for all those asking how...
Old May 5, 2003 | 07:21 PM
Kermit EK's Avatar
zip ties own!
Old May 5, 2003 | 07:39 PM
hanson said's Avatar
Default Re: Easy How To:Keep your shift boot up (Kermit EK)
you can also push a skateboard bushing down on the shifter. same concept as using zipties, just a larger base.
Old May 5, 2003 | 07:50 PM
BB2's Avatar
BB2
if you'd invert that rubber plug it would work and probably look better. i could be wrong but to me the plug looks like a cone if its not than ignore my post
Old May 5, 2003 | 09:02 PM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">
Just take the boot off after you find how far the shift **** sits, then wrap some electrical tape around the shifter, </TD></TR></TABLE>
That's how I did it but w/ an appropriately-sized rubber grommet.
Old May 5, 2003 | 09:21 PM
Ovaltine's Avatar
Default Re: (humblelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by humblelude &raquo;</TD></TR><TR><TD CLASS="quote">if you'd invert that rubber plug it would work and probably look better. i could be wrong but to me the plug looks like a cone if its not than ignore my post</TD></TR></TABLE>
Naw, if you invert it, the lines wouldn't be even like it is now. It looks as is.
Old May 5, 2003 | 09:28 PM
Default Re: (Ovaltine)
franks, I was wating for a positive comment
Old May 5, 2003 | 09:37 PM
six_speed's Avatar
Default Re: (TerribleOne)
washers can also do the trick, the rubber doesn't look too pretty imo.
Old May 5, 2003 | 09:45 PM
Buckshot's Avatar
Default Re: (Humping_dragon)
whats so wrong with the boot sliding around? i kinda like it
Old May 5, 2003 | 09:47 PM
Default Re: (Buckshot)
to each their own...
Old May 6, 2003 | 01:02 AM
NrG's Avatar
NrG
been coding out the ecu i see
Old May 6, 2003 | 04:11 AM
JasonBlackEJ1's Avatar
i actually like it when it hangs down a little bit.
Old May 6, 2003 | 04:31 AM
Default Re: (NrG)
hehe yah
Old May 6, 2003 | 07:48 AM
Kalokohan's Avatar
New User
Just take off the boot and wrap a bunch of electrical tape below the boot to hold it up next to the shifter.
Old May 6, 2003 | 09:01 AM
sivik2nr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">same thing I did, but with electrical tape....lol.</TD></TR></TABLE>
Yeah me too!!
Old May 6, 2003 | 09:05 AM
jdm4life's Avatar
Looking good........but i don't mind it dipping down...on the Type-R's i think they slide around unattached
Old May 6, 2003 | 10:17 AM
V-Grip! Teknic73's Avatar
Default Re: Easy How To:Keep your shift boot up (jdm4life)
ive used electric tape but it stil drops down. i've never tried a zip tie, but im diggin that rubber deal. you wanna make me one?
Old May 6, 2003 | 10:29 AM
One2chi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kermit EK &raquo;</TD></TR><TR><TD CLASS="quote">zip ties own! </TD></TR></TABLE>
i zipties
Old May 6, 2003 | 10:31 AM
Ekizzle's Avatar
Default Re: Easy How To:Keep your shift boot up (One2chi)
