86 crxsi swaps and cost?
Old May 5, 2003 | 04:42 PM
brechdofragen's Avatar
Default 86 crxsi swaps and cost?
i'm new in this deal, but what kind of engines could you swap into a 86 crx si and how much would it cost after mounts and all other needed parts
Old May 5, 2003 | 05:01 PM
Losrocket_'s Avatar
Default Re: 86 crxsi swaps and cost? (brechdofragen)
A D16a1 would be the cheapest because it bolts right in. Simple swap into an Si. You can also do a Bseries but it requires mounts, linkage, axles, wiring harness and of course the swap itself. It usually gets pricey because of the mounts and all that stuff. At a local shop here a Bseries into an '86-87 Si costs about $4000 to $4500. Thats a B16a1 with all required parts and labor, out the door for that price.
Old May 5, 2003 | 05:05 PM
djay86's Avatar
Default Re: 86 crxsi swaps and cost? (Losrocket_)
hey, i was just curious, how fast are those d16a1 1st gen CRX's
Old May 5, 2003 | 07:26 PM
jlicrx's Avatar
[QUOTE=Losrocket_] A D16a1 would be the cheapest because it bolts right in. Simple swap into an Si. QUOTE]
true, the engine bolts right in - you still need transmission, axles, knuckles/hubs, shift linkage and ecu, all from 86-87 integra - also, quite a few wiring changes
1997 gsr
19
Apr 20, 2009 10:41 AM
radeonboy
Apr 8, 2009 04:57 PM
frankboy1269
Oct 30, 2006 08:51 PM
kcjohnnyboy
Feb 23, 2006 10:50 PM
spyz34
Nov 18, 2004 11:19 AM
