ECU flashing code 4 plus not reving past 4k
Old May 5, 2003 | 04:03 PM
powerLINEinteg's Avatar
Default ECU flashing code 4 plus not reving past 4k
ZC Q'S....
WHERE IS CRANK ANGLE SENSOR LOCATED?
4 FLASHES IS CRANK ANGLE SENSOR....RIGHT?
Also motor wont rev past 4000rpm...back fired once
Throttle is getting WOT
The two white wire that are added during a SI to ZC swap do nothing.. If there connected and you un do them there is no difference in the motor sound or performance..
Old May 5, 2003 | 05:23 PM
civickiller's Avatar
Default Re: ECU flashing code 4 plus not reving past 4k (powerLINEinteg)
isnt the crank sensor on the end of the cam
Old May 6, 2003 | 07:57 AM
white99gsr's Avatar
Default Re: ECU flashing code 4 plus not reving past 4k (civickiller)
well, first of all what distributor are you running? you need a 88-91 Si, HF, or EX distributor. The Crank Angle Sensor is inside the distributor. Your right, the two added wires don't do dick without the right distributor, I had the same problem, except i have a JDM D15b in a 91 hatch. Also, make sure you switched the grn/wht and yel/wht wires on the TPS Sensor. If you have any more issues let me know. I know how you feel, I've gone through it.
Jtkdirtbike
Sep 7, 2013 06:47 PM
project91crxsi
Aug 5, 2010 11:26 AM
KURUPTinc
Oct 28, 2005 10:17 AM
YellowR2000x2
Mar 4, 2005 04:29 PM
ZColeon
Jun 27, 2002 04:40 PM
