Golden Eagle Turbo Oil Feeds (old style) $79 shipped
Old May 5, 2003 | 04:02 PM
Howitt's Avatar
Default Golden Eagle Turbo Oil Feeds (old style) $79 shipped
Modified by Howitt at 2:45 PM 5/21/2003
Old May 5, 2003 | 06:47 PM
GOLDBERG's Avatar
Default Re: Golden Eagle Turbo Oil Feeds (old style) $79 shipped (Howitt)
pics??
Old May 5, 2003 | 07:19 PM
Howitt's Avatar
Default Re: Golden Eagle Turbo Oil Feeds (GOLDBERG)
Old May 5, 2003 | 07:27 PM
SpoolinSol's Avatar
Default Re: Golden Eagle Turbo Oil Feeds (Howitt)
IM sent.
Old May 5, 2003 | 08:21 PM
Howitt's Avatar
Default Re: Golden Eagle Turbo Oil Feeds (SpoolinSol)
sent ya one back
Old May 6, 2003 | 01:46 AM
GOLDBERG's Avatar
whatsup with that massive nipple?? can u remove that and plug the hole??? also when fully tightened, in what direction is that 1/8 hole facing??? thnx
Old May 7, 2003 | 08:02 PM
Howitt's Avatar
thats a -6an nipple, yes you can remove it and plug it, the hole faces where ever you please
Old May 7, 2003 | 09:23 PM
99ls's Avatar
I'll take one with fittings for 1/8 npt. IM sent.
Old May 8, 2003 | 01:39 PM
Howitt's Avatar
Default Re: Golden Eagle Turbo Oil Feeds (99ls)
I got some on the way they will be here monday
Old May 11, 2003 | 06:28 PM
Howitt's Avatar
bump
Old May 11, 2003 | 09:17 PM
HYBRID_H@TCH's Avatar
I will take one.sending IM right now.
Old May 11, 2003 | 10:32 PM
int3gra's Avatar
what does the new one look like?
Old May 12, 2003 | 02:34 PM
Howitt's Avatar
Default Re: Golden Eagle Turbo Oil Feeds (int3gra)
just like the old one but with a female instead of male connector
Old May 18, 2003 | 07:18 PM
Howitt's Avatar
bump got 1 left in stock
Old May 19, 2003 | 07:19 PM
Howitt's Avatar
bump
Old May 19, 2003 | 08:05 PM
magicwand's Avatar
does the new one have an advantage over the old one?
Old May 20, 2003 | 07:39 AM
X-Mazda 3 Racer's Avatar
Default Re: Golden Eagle Turbo Oil Feeds (magicwand)
The only reason we redesigned it was to allow it to be used in conjunction with an oil cooler. With the old unit, you cannot use an oil cooler on your block.
Old May 20, 2003 | 08:15 PM
Howitt's Avatar
Default Re: Golden Eagle Turbo Oil Feeds (GoldenEagleMfg.com)
bump
Old May 22, 2003 | 11:43 AM
magicwand's Avatar
so with the new design it has ports for vtec and oil cooler in and out or do you drain back to the pan?
Old May 22, 2003 | 12:52 PM
Howitt's Avatar
it oil cooler compatible, meaning you could using a greddy oilcooler with it, its not meant to be a oil cooler but I could see with some adaptions it could happen
Old May 22, 2003 | 02:17 PM
BoostedSOHC's Avatar
still got that one in stock? i just need to call Apex'i to find out what size fittings come with there kit so i know what to order with it!
Old May 22, 2003 | 05:30 PM
Howitt's Avatar
Default Re: Golden Eagle Turbo Oil Feeds (BoostedSOHC)
sent you a PM
turboteg2nv
Feb 21, 2013 09:15 AM
x32laro
Dec 8, 2009 09:23 PM
Mr.60trim
Jul 26, 2007 12:01 PM
PHiZ
Mar 10, 2005 01:45 PM
karmannghia
Dec 13, 2003 04:37 PM
