Skunk2 Cam Gear Install ???
Old May 5, 2003 | 02:52 PM
hYpE-R-29's Avatar
Default Skunk2 Cam Gear Install ???
A friend of mine is doing my Cam Gear install tom. I want to know should I watch out for any problems with the install? it will be set at 0 degree till I get to DSR later on this week, so will I be able to run still at stock idle for a couple of days?
*Any advice would be Great*
Old May 5, 2003 | 03:22 PM
slowman's Avatar
I took way too long
Default Re: Skunk2 Cam Gear Install ??? (hYpE-R-29)
hehe, it's a piece of cake. just make sure you leave tension on the timing belt when you take it off. i did this using a zip tie thing and found a hole to put the tie through on my engine mount. really simple install.
Old May 5, 2003 | 03:23 PM
hYpE-R-29's Avatar
Default Re: Skunk2 Cam Gear Install ??? (slowmanEF)
thnx and the timing should be still stock til I get tuning?
Old May 6, 2003 | 04:43 AM
RDLIN-IT's Avatar
One thing to remember is that timing marks on the cam gears are in 2 degree increments. When I put mine on I was told each one was one degreee and the car would stall.
Old May 6, 2003 | 04:48 AM
TypeR 01 886's Avatar
Default Re: Skunk2 Cam Gear Install ??? (RDLIN-IT)
Would cam gears be an advantage on a stock typer?
Old May 6, 2003 | 04:50 AM
RDLIN-IT's Avatar
Default Re: Skunk2 Cam Gear Install ??? (TypeR 01 886)
If its completely stock I would spend the money on a intake or header first.
Old May 6, 2003 | 05:00 AM
Well I have intake... but I consider that stock
Ek4 life
Nov 29, 2007 08:06 AM
preludejayes
Sep 13, 2007 11:37 PM
rotorhead70
Mar 2, 2003 09:48 PM
Buckshot
Jan 14, 2003 08:03 AM
agent marlon
Nov 19, 2002 07:58 PM
