Is there a difference between a type r flywheel and a gsr flywheel?
Old Jul 5, 2001 | 06:08 AM
ITS BONE STOCK I SWEAR's Avatar
New User
Default Is there a difference between a type r flywheel and a gsr flywheel?
I know that the type r flywheel is a little lighter, how much lighter I do not know. If i swap out my gsr flywheel and put in a type r flywheel (buddy has one for me) is it worth it? will i feel a difference? I know that for the cost of install it probably isnt, but I have to open her up anyways, need a new clutch
thanks in advance.........
Old Jul 5, 2001 | 06:15 AM
jbsadler's Avatar
New User
Default Re: Is there a difference between a type r flywheel and a gsr flywheel? (slapmyfro)
The ITR Flywheel is about 14 lbs and the GSR is about 17 lbs. Doesn't seem like a big diff but it really is. Check out a GSR and ITR flywheel side by side and you'll see why.
Old Jul 5, 2001 | 06:24 AM
Mike K's Avatar
Default Re: Is there a difference between a type r flywheel and a gsr flywheel? (jbsadler)
Actually, it is 5 lbs. difference. I weighed them. But then again, I weighed the ITR against a LS. The LS and GSR flywheels are different part numbers.
ITR=13lbs.
LS=18lbs.
GSRrobably 18 or 17lbs.
Old Jul 5, 2001 | 12:56 PM
GZR4DR's Avatar
Default Re: Is there a difference between a type r flywheel and a gsr flywheel? (Mike K)
GSR flywheel is lighter than an LS, that i know for sure. 16-17lbs seems about right. I use an 11lb HKS flywheel however, and it revs like no other.
Rob1242
Mar 6, 2006 03:07 PM
Galaxy Si
Jan 18, 2005 06:56 AM
MugenDC4
Jul 18, 2004 09:27 PM
Obee1.8
Jul 2, 2003 05:17 PM
